跳转到主内容
2011 Hyundai Elantra Tail Light Replacement
你所需要的
  1. 2011 Hyundai Elantra Tail Light Replacement, Tail Light: 步骤 1 中的图像 1,1
    • Open the trunk.
    • Lift the latch built into the carpet liner on the right side. Remove the cover in order to see the bulb covers.
    • Be careful to not rip the carpet upon removal.
  2. 2011 Hyundai Elantra Tail Light Replacement: 步骤 2 中的图像 1,3 2011 Hyundai Elantra Tail Light Replacement: 步骤 2 中的图像 2,3 2011 Hyundai Elantra Tail Light Replacement: 步骤 2 中的图像 3,3
    • You will then use your 10mm socket to remove three nuts, careful not to strip the screw to ensure easy replacement.
  3. 2011 Hyundai Elantra Tail Light Replacement: 步骤 3 中的图像 1,2 2011 Hyundai Elantra Tail Light Replacement: 步骤 3 中的图像 2,2
    • Once the bolts are removed, you will need to remove the wires connected to the bulb casing. Firmly push in on the center piece at the base of the wire and pull directly out to remove.
  4. 2011 Hyundai Elantra Tail Light Replacement: 步骤 4 中的图像 1,2 2011 Hyundai Elantra Tail Light Replacement: 步骤 4 中的图像 2,2
    • Once the wires are disconnected facing the bumper, firmly grasp the entire plastic casing of the tail light and pull directly towards your hips in order to not catch the hidden clip located on the side of the car near the end of the tail light casing.
  5. 2011 Hyundai Elantra Tail Light Replacement: 步骤 5 中的图像 1,3 2011 Hyundai Elantra Tail Light Replacement: 步骤 5 中的图像 2,3 2011 Hyundai Elantra Tail Light Replacement: 步骤 5 中的图像 3,3
    • In order to remove the main brake/tail light, remove small light first. This is the same process for the main light. Using pliers grip the plastic and pull while rotating counterclockwise 30 degrees and remove the bulb from the socket.
    • Repeat this step to remove main bulb as well.
  6. 2011 Hyundai Elantra Tail Light Replacement: 步骤 6 中的图像 1,2 2011 Hyundai Elantra Tail Light Replacement: 步骤 6 中的图像 2,2
    • Put a new Sylvania long life bulb into the socket until you hear it click.
  7. 2011 Hyundai Elantra Tail Light Replacement: 步骤 7 中的图像 1,2 2011 Hyundai Elantra Tail Light Replacement: 步骤 7 中的图像 2,2
    • You can now begin the re assembly of parts. Start by re assembling the plastic cap to create a water proof seal.
  8. 2011 Hyundai Elantra Tail Light Replacement: 步骤 8 中的图像 1,2 2011 Hyundai Elantra Tail Light Replacement: 步骤 8 中的图像 2,2
    • After you seal the bulb, you will then place the entire casing back into the bumper ensuring that the hidden clip mentioned earlier is attached. Then, re attach the wires, you should hear a clicking sound when wire is properly placed in socket.
  9. 2011 Hyundai Elantra Tail Light Replacement: 步骤 9 中的图像 1,2 2011 Hyundai Elantra Tail Light Replacement: 步骤 9 中的图像 2,2
    • Next you will need to screw on the three bolts used previously with a 10 mm socket making sure they are tight and secure.
  10. 2011 Hyundai Elantra Tail Light Replacement: 步骤 10 中的图像 1,3 2011 Hyundai Elantra Tail Light Replacement: 步骤 10 中的图像 2,3 2011 Hyundai Elantra Tail Light Replacement: 步骤 10 中的图像 3,3
    • Reattach the carpet liner and close the trunk.
    • Test your bulb and make sure it is running properly.
结论
Wade Carter
于01/23/19注册
181 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 24
过去 30 天: 74
总计 4,109
