简介
使用本指南更换坏掉的电池。如果你的电池鼓包了,请采取额外措施。
使用电池顶部的塑料拉手拉出电池。
把电池充满,然后至少继续充电两个小时。之后,像往常一样使用它,消耗电量。当你看到低电量警告时,保存好你的工作,然后让笔记本开着,直到它因为低电量而入睡。再等待至少五个小时,之后再把你的笔记本充满到100%
如果在安装新电池后你发现了一些异常状况或麻烦,你可能需要重置你的Macbook的设备管理器
按照本指南相反步骤来重新组装设备。
按照本指南相反步骤来重新组装设备。
289等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
15条评论
as the label said, "Warning, do not remove the battery", is that any risks if I disobey it?
Actually Monika, the guide says that a Tri-wing is needed for two of the screws, which it is. My new battery came with a tool for that but I'd already discovered that it's easy to remove these two screws with a fine straight (non-Philip's head) driver.
Thanks Phillip Takahashi (and your five co-authors). That was a straight forward and clear guide.
mouldfield - 回复
Hello
I changed the battery and it keeps telling me that there is replacement needed
Also the indicator said the battery is 150% charged.
Is that normal and how do i remove the status that said the battery isn't ok and change it in to an ok status?
Please help
