简介
Change the oil in your 2006-2011 Honda Civic to keep it running strong and improve engine longevity. This guide will cover all models equipped with the 1.8L engine.
Honda recommends an oil change when the maintenance light comes on, or after one year, whichever comes first. In tough driving conditions with a lot of stop-and-go traffic, the maintenance light will come on after about 6,000 miles, indicating 15% oil life remaining.
你所需要的
Place a jack at the jacking point at the front passenger side on the pinch weld, the thicker metal part just behind the front wheel.
Use the jack to lift the passenger side of the car until you have enough room to work under the car comfortably.
Once the oil has slowed to a drip, wipe off the area around the drain plug with a clean rag or towel.
Reinstall the drain plug and tighten it with a box end wrench until it is snug. Alternatively, you can use a torque wrench to verify that the plug is tightened to spec. The torque spec for the drain plug is 29 ft./lbs. (39 Nm)
Dip a clean gloved finger into a new bottle of oil and spread a thin layer of oil over the gasket on the new oil filter.
Wipe off the oil filter threads and contact area on the engine with a clean rag or towel.
Place the new filter over the threads and turn it clockwise by hand until it is snug.
Remove the orange dipstick from under your hood.
Wipe the dipstick down with a rag or towel to ensure that you get a true reading.
Reinsert the dipstick all the way into its hole, then remove it.
The amount of oil on your dipstick determines the oil level. The top of the crosshatched area is the maximum amount of oil you should have, while the bottom of the crosshatching is the minimum.
When it's time to change the oil in your Civic, the maintenance light (orange wrench) will appear on your dash, as well as a B1 message, showing an oil life of 15% or less.
To reset the Oil Life % gauge, press and hold the SEL/RESET button for about 10 seconds until the Oil Life message begins to flash. Release the SEL/RESET button, and hold it again for about 5 seconds until the Oil Life % resets to 100.
Allow 12-24 hours for all of the oil to drain out of the old oil filter.
Take your old oil and filter to a recycling facility. Most auto parts stores and repair shops accept these at no charge to you. In addition, some cities and/or counties have a service where they will collect used oil and filters from your home. For more information, see the American Petroleum Institute's web page on used motor oil collection and recycling.
108等其他人完成本指南。
43指南评论
To actually reset the oil light:
1. Hold button for 10 sec
2. Release and rotate button counter clockwise once to select "oil life" (it should be flashing)
3. Press button once (makes whole display flash)
4. Hold button for 5 seconds until it says 100%
To actually reset the 2009 Civic you won’t be rotating the button it’s not like that. It’s exactly like the author states.
Greetings from Russia! Thanks for the lesson.
Exactly what you look for in a How-To guide
