当前版本的文档还未经巡查,您可以查看最新的已查核版本 。
Jack up the front of the car and place it on jack stands.
Never work on or underneath a car that is only supported by a jack. The jack may slip or fail, resulting in serious injury or even death.
Use an impact wrench or lug wrench to remove the five 19 mm lug nuts from the front wheel.
The wheel lug nuts should be torqued to 85 ft-lbs when the wheels are put back on the car.
Pull the front wheel off the wheel lugs and set it aside.
Place the wheel adapter over the existing wheel lugs, then install and hand-tighten the provided lug nuts.
Tighten the lug nuts to 85 ft-lbs with a torque wrench or impact gun.
The choice is yours as to what adapters you'd like to install. We chose 5x4.75 adapters so that we could equip our Volvo 240 with C4 Corvette wheels!
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
单个步骤
完整指南
小——600像素
中——800像素
大——1200像素
预览
