跳转到主内容
1986-1993 Volvo 240 Spark Plug Wires Replacement
你所需要的
  1. 1986-1993 Volvo 240 Spark Plug Wires Replacement, Spark Plug Wires: 步骤 1 中的图像 1,1
    • To avoid any confusion between which wire goes to which spark plug, replace spark plug wires one at a time. You may want to mark either the old or new wires to remind yourself which ones you've changed.
    • Disconnect the spark plug wire from the distributor cap by pulling it straight up.
  2. 1986-1993 Volvo 240 Spark Plug Wires Replacement: 步骤 2 中的图像 1,2 1986-1993 Volvo 240 Spark Plug Wires Replacement: 步骤 2 中的图像 2,2
    • Gently twist the spark plug boot back and forth and pull up to remove it from the spark plug.
    • When installing your new spark plug wires, it's a good idea to apply dielectric grease to the spark plug boots to prevent the electrical connections from being damaged by water or debris.
结论
Install your new spark plug wires in the same manner that you removed the old ones.
2等其他人完成本指南。
David Hodson
于04/13/10注册
150,503 声望
创作了127篇指南
2条评论
Doing this today. Thanks for the clear, reassuring steps to get it done :)
jeconnol - 回复
These directions were great! Thank you. I got the wires on in about 40 minutes. Oh, and I’m a girlie girl. :)
Nancy - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 4,019
