跳转到主内容
(Fat) Xbox 360 Hard Drive Replacement
你所需要的
  1. (Fat) Xbox 360 Hard Drive Replacement, Remove the bottom screws: 步骤 1 中的图像 1,3 (Fat) Xbox 360 Hard Drive Replacement, Remove the bottom screws: 步骤 1 中的图像 2,3 (Fat) Xbox 360 Hard Drive Replacement, Remove the bottom screws: 步骤 1 中的图像 3,3
    • Buy the drive at a cost you can afford to eat. This will void any warranties offered.
    • Remove the 3 screws from the bottom of the drive. Use a T6 Torx driver.
    • Remove the warranty seal and final screw. Use a T6 Torx driver.
  2. (Fat) Xbox 360 Hard Drive Replacement, Disassembly tip: 步骤 2 中的图像 1,1
    • If the drive is difficult to open and you are opening it to put the drive into a later Xbox 360 with no intention to preserve the enclosure, a screwdriver or pry tool can help.
    • If you are opening it to replace the drive inside for an original console, it is best to use a plastic pry tool instead. While a screwdriver "works" it will likely mar the enclosure.
  3. (Fat) Xbox 360 Hard Drive Replacement, Open the drive: 步骤 3 中的图像 1,3 (Fat) Xbox 360 Hard Drive Replacement, Open the drive: 步骤 3 中的图像 2,3 (Fat) Xbox 360 Hard Drive Replacement, Open the drive: 步骤 3 中的图像 3,3
    • If you are taking the enclosure apart for the bare drive, less caution is needed.
    • After removing the 4 bottom screws, remove the top cover. Remove the spring and locking tab before removing the drive cage.
    • Remove the drive cage from the drive enclosure. If the drive has never been opened, additonal force may be required.
  4. (Fat) Xbox 360 Hard Drive Replacement, Disconnect and remove the hard drive: 步骤 4 中的图像 1,3 (Fat) Xbox 360 Hard Drive Replacement, Disconnect and remove the hard drive: 步骤 4 中的图像 2,3 (Fat) Xbox 360 Hard Drive Replacement, Disconnect and remove the hard drive: 步骤 4 中的图像 3,3
    • Remove the four T10 Torx screws securing the hard drive.
    • After removing the screws, slide the top cover off and disconnect the drive.
    • Disconnect the hard drive and remove it from the enclosure.
终点
9等其他人完成本指南。
Nick
于11/10/09注册
89,943 声望
创作了52篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,525篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 69
过去 30 天: 296
总计 10,013
