简介
希望 MacBook Pro 的脚垫变得焕然一新吗?快根据本指南的指引为你的配备 13 英寸 Retina 屏幕的 MacBook Pro(2015 年初) 更换新的脚垫吧。
你所需要的
在这个步骤中使用的工具:Magnetic Project Mat$19.95
将固定在顶盖和背盖的螺丝卸除:
两个 2.3mm的P5五角螺丝
八个3.0mm的P5五角螺丝
想要重新组装设备,请按照指南中逆序进行操作即可
64等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
8指南评论
On the inside of the cover of my A1502 Early 2015 MBP, two of the four feet are covered by large black stickers. So, how do we remove the little piece left behind when we remove any foot that is damaged? Do we just cut through the large black sticker or remove it?
This review was helpful, but it didn’t mention the black stickers on the inside of the lower case. I ended up poking a small hole through the black stickers to get the remaining pieces of previous feet out.
Just peel them back as far as needed, then re-stick them back when you're done. In my case, one did re-stick easily, while the other one didn't, I used a small piece of electrical tape to stick it back. It doesn't really matter that much, either way.
Jason and Taylor, the stickers you mention are on Step 4 of this guide.
