简介
请按照本指南更换 Nintendo Switch 上破裂或损坏的后面板。
Switch使用 JIS 螺钉。JIS 00 螺丝刀效果最好,但您也可以使用 JIS 000 螺丝刀。如果您使用十字螺丝刀,则可能会使螺丝拧花。
注意:*** 本指南以及我们销售的零件与 2017 年发布的原始 Nintendo Switch 型号以及 2019 年发布的更新型号(型号分别为 HAC-001 和 HAC-001(-01))兼容。
你所需要的
将新替换部件与原始部件进行比较。在安装之前,您可能需要从新部件转移剩余组件。
要重新组装设备,请按照逆序进行操作。
请将维修过程产生的电子垃圾带到R2或e-Stewards认证的回收站。
维修没有按计划进行吗?尝试一些基本故障排除后的故障排除,或向我们的任天堂 Switch 问答社区寻求帮助。
89等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
11指南评论
Excellent and concise guide.
The new panel doesn’t come with the sticky grille pieces x 2 on the bottom. Is it supposed to be a straight transfer between the old and the new?
You can transfer the grill to the new back plat
Just did this replacement and there are a few things to keep in mind that this review does not mention. There are x2 square foam pieces that can be transferred to the new panel located at the bottom backside of the old. Also, the game cartridge shield hardware and the kickstand holder hardware have to be taken off the back of the old panel and transferred to the new panel. The kickstand has 2 Phillips #000 screws and the game cartridge shield has 1 Phillips #000 screw
Is the casing the same between the HAC model and the HAD model? This guide doesn’t specify
