简介
我不得不写一个单独的教程因为这款MacBook Pro搭载了Apple T2芯片所以与其他Mac笔记本的步骤不同。
选取苹果 () 菜单 >“关机”
在Mac关机后,同时按住左侧的Shift键、左侧的Option键和Control键 7 秒钟。随后,继续按住这些按键的同时,再按住电源键7秒钟。
松开所有按键,稍等几秒钟。
再次按电源键打开Mac
重置后依然无效吗?请至我们的论坛 寻求帮助。
49等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
19指南评论
Macbook Pro 2018, 15” (I presuming no difference in operation).
After your Mac shuts down, press and hold the right Shift key, the left Option key, and the left Control key for 7 seconds. Then keep holding those keys while you press and hold the power button for another 7 seconds.
The Macbook fires up as soon as the touchbar power button is pressed. Depressing all ⇧⌃⌥⎋ together, or depressing ⇧⌃⌥ and then adding ⎋ makes no difference. Depressing! ,-)
Nope. Doesn’t work on a 2018 MacBook Pro with Touchbar. Pressing any key boots up the computer and holding Command-Option-P-R doesn’t have any effect as it did on previous models.
Yep, new macbooks behave terribly on boot. It’s probably part of the problem. Did anyone ask for this “start on lid open” BS?
SOlution: do not press the right shift key!!!! Press all the keys on the left side of the keyboard including the Shift key- otherwise it will power on your MAc normally. IF you do the left side it wont power - do this for 10 sec then release and then power on normally- this will reset the SMC on touch bar MBP
