跳转到主内容
简介
便宜的烟雾器因为质量差常常容易损坏。多数故障可以轻松修复。这份指南可用于维修这类烟雾器最常见的毛病。
我修的烟雾器名字叫做 'eurolite n-19',但也可能以别的名字出售。
配件
没有特定配件。
  1. 打开烟雾器之前需要用螺丝刀拆掉图中的螺钉。
    • 打开烟雾器之前需要用螺丝刀拆掉图中的螺钉。
    • 拆掉烟雾器的外壳。
  2. 如果烟雾器不能加热保险丝,则加热单元可能坏了。
    Link is spam. (As you may have guessed after reading this far, the author isn't actually trying to help you fix your machine.) Don't click the link to the guide.
    Daniel Jackson - 回复
  3. 备齐必要的维修工具
    • 备齐必要的维修工具
    • 本例中,仅需要一根新的加热电阻丝和一个新的铲形接头。
    • 拆下加热电阻丝
    • 拆下铲形接头
    • 把新的加热电阻丝和铲形接头连接到它们各自应在的位置。
    • 加热电阻丝位于双金属器件的下方(图中看不清楚)
  4. 简单按逆序操作上述步骤以重组烟雾器。
    • 简单按逆序操作上述步骤以重组烟雾器。
    Where did you find the parts? (Heat fuse)
    Todd Maxwell - 回复
结论
重新组装你的设备,请反转以下步骤的操作顺序。
4等其他人完成本指南。
特别感谢这些译者︰
41%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
rjay
于2012年09月29日注册
206 信誉积分
撰写一个指南
My fogger heater is jam how can I clean it?
vishal_kishor777 - 回复
hmm… I think I could have written a better guide myself. Okay so I have a 3 pin XLR for phase does anyone know how this works also I noted that the fuse was melted into its holster and the pump seems dead. My Fogger also has some kind of potentiometer which controls the heating element which is like a ceramic sandwich and two spark plugs… I also was wondering if glycerin fog juice can be made with vegetable glycerin or the glycol type or if this is what cloggs the machine. Also will clr work or be dangerous fume wise? Can you market glycerine as fog juice thickener like STP fuel additives for cars?? g0pg.xyz is my website you can learn how to force push graphite if you look for the post with yoda!
Ember Leona - 回复
Where can I buy a fuse like this? Have looked over the net, but could not find any shops that would sell CH-15 fuse, used in this fog machine. If anyone knows about this, please share info. Thanks! By the way, I’m based in EU.
Giedrius Stasiulis - 回复
My fog machine is not pumping out smoke
Ohwaga Kerry - 回复
No power to my fog machine ?
David McCartie - 回复
My FM400-1 fog machine pumps out fog for 1 minute then stops, cools and then pumps out fog for another minute then stops again. Is this normal or is the safety device wearing out?
Paul Houle - 回复
添加评论
浏览统计数据:
过去的24小时: 16
过去的7天: 79
过去的30天: 385
总计 46,314
