简介
你的Zippo打火机打不着了?可能是燃料耗尽!别担心,买一些打火机燃料,这份指南将教会你如何给你的Zippo打火机填充燃料。
你所需要的
解开曲别针,将曲别针的一端插入小孔中,提起毛毡。
FWIW, the tiny hole is designed and perfectly sized for a spare flint. When off in the world and your lighter has fuel but will not spark, having a flint handy can mean the difference between flame or frustration
25等其他人完成本指南。
由衷感谢以下译者:
91%
tracy zhu正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
4条评论
I do have money to buy fluid could i put fluid from another lighter in it
Howdy Trinity - it’s possible, but unlikely, that would work.
Zippo uses a white gas/naphtha type fuel. BIC, and most other encased plastic lighters, use butane type fuel.
Butane has to stay in a tightly sealed container or it will evaporate within a few minutes. Zippo lighters do not have this tight of a seal (even when upgraded with rubber or silicone gaskets).
If you have another Zippo lighter with the correct fluid in it I would recommend transferring the insert. This is easier than attempting to transfer the fluid itself as that is a complicated process resulting in losing a lot of the fluid anyway.
It’s possible to use non-branded forms of white gas/naphtha fluid in a lighter but I can’t recommend using anything other than “lighter fluid”. Other naphtha type fuels have application specific additives and may be extremely toxic.
PLEASE NOTE: some fluids marked as “white gas” are actually additive-free gasoline. This is highly explosive and therefore extremely dangerous to use as a lighter fluid.
Bird -
I always check the flint is still striking a spark before refilling as this is much less messy when the lighter is empty rather than full.
If there is no spark when triggered then the flint probably needs renewing, if there is spark and no ignition then refill,
You can also use old bic lighters for the flint, the life of the fluid ends far passed the life of the flint.
