跳转到主内容
How to refill a Zippo Lighter
你所需要的
  1. How to refill a Zippo Lighter, How to refill a Zippo Lighter: 步骤 1 中的图像 1,1
    • Purchase lighter fluid – any type but do not use lighter fluid intended for barbecuing.
  2. How to refill a Zippo Lighter: 步骤 2 中的图像 1,2 How to refill a Zippo Lighter: 步骤 2 中的图像 2,2
    • Open the lid of the Zippo and extract the insert – firmly grip either side of the flint wheel with 2 fingers. Hold the bottom of the Zippo lighter with your other hand and pull up on the metal to free the insert of the lighter from its case.
  3. How to refill a Zippo Lighter: 步骤 3 中的图像 1,1
    • Set aside the metal casing.
  4. How to refill a Zippo Lighter: 步骤 4 中的图像 1,1
    • Turn the insert upside down – there should be a felt bottom that reads “Lift to fuel.”
  5. How to refill a Zippo Lighter: 步骤 5 中的图像 1,1
    • Unravel the paperclip. Lodge one end of the paper clip into the tiny hole and lift up the felt backing.
  6. How to refill a Zippo Lighter: 步骤 6 中的图像 1,1
    • Squeeze the lighter fluid can once into the loose cotton.
    • If your lighter fluid canister is large, you may want to transfer the fluid to a smaller bottle to prevent spillage.
  7. How to refill a Zippo Lighter: 步骤 7 中的图像 1,1
    • Wait 5 seconds, then squeeze the canister twice more into the cotton.
  8. How to refill a Zippo Lighter: 步骤 8 中的图像 1,1
    • Close the felt protector.
  9. How to refill a Zippo Lighter: 步骤 9 中的图像 1,1
    • Place the metal box back into the case.
  10. How to refill a Zippo Lighter: 步骤 10 中的图像 1,1
    • Let the Zippo sit and absorb the fluid for 1-2 minutes.
    • While waiting, wash your hands.
    • Done! Light the Zippo.
终点
25等其他人完成本指南。
Danielle Tran
于02/24/15注册
709 声望
撰写一个指南
团队
Cal Poly, Team 23-4, Green Winter 2015 Cal Poly, Team 23-4, Green Winter 2015 的会员
CPSU-GREEN-W15S23G4
7 名成员
创作了15篇指南
4指南评论
I do have money to buy fluid could i put fluid from another lighter in it
Trinity Bullock - 回复
Howdy Trinity - it’s possible, but unlikely, that would work.
Zippo uses a white gas/naphtha type fuel. BIC, and most other encased plastic lighters, use butane type fuel.
Butane has to stay in a tightly sealed container or it will evaporate within a few minutes. Zippo lighters do not have this tight of a seal (even when upgraded with rubber or silicone gaskets).
If you have another Zippo lighter with the correct fluid in it I would recommend transferring the insert. This is easier than attempting to transfer the fluid itself as that is a complicated process resulting in losing a lot of the fluid anyway.
It’s possible to use non-branded forms of white gas/naphtha fluid in a lighter but I can’t recommend using anything other than “lighter fluid”. Other naphtha type fuels have application specific additives and may be extremely toxic.
PLEASE NOTE: some fluids marked as “white gas” are actually additive-free gasoline. This is highly explosive and therefore extremely dangerous to use as a lighter fluid.
Bird -
I always check the flint is still striking a spark before refilling as this is much less messy when the lighter is empty rather than full.
If there is no spark when triggered then the flint probably needs renewing, if there is spark and no ignition then refill,
Richard Morgan - 回复
You can also use old bic lighters for the flint, the life of the fluid ends far passed the life of the flint.
Phillip kalanick - 回复
添加评论
浏览统计数据:
过去 24 小时: 13
过去 7 天: 77
过去 30 天: 252
总计 156,722
