跳转到主内容
How to Calibrate an Optical Fingerprint Sensor
  1. How to Calibrate an Optical Fingerprint Sensor, Download the app: 步骤 1 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor, Download the app: 步骤 1 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor, Download the app: 步骤 1 中的图像 3,3
    • Download the Self Repair Assistant app (2.0.12)here.
    • You may be prompted with a "File might be harmful" warning. If so, select "Download anyway."
    • Open the "My Files" app.
    • Navigate to the "Installation files" tab on the left side of the screen.
  2. How to Calibrate an Optical Fingerprint Sensor, Install the app: 步骤 2 中的图像 1,2 How to Calibrate an Optical Fingerprint Sensor, Install the app: 步骤 2 中的图像 2,2
    • Select the app on the right side of the screen.
    • If the app doesn't show up on this panel, skip to the next step.
    • Select "Install" to confirm the app's installation.
    • Skip the next two steps.
  3. How to Calibrate an Optical Fingerprint Sensor, Rename the app: 步骤 3 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor, Rename the app: 步骤 3 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor, Rename the app: 步骤 3 中的图像 3,3
    • If your app didn't show up on the "Installation files" tab, follow the next two steps to rename the file.
    • Navigate to the "Downloads" tab on the left side of the screen.
    • Long press the download file until an orange checkmark appears to the left of it.
    • Navigate to the bottom of the screen and select the "More" option.
  4. How to Calibrate an Optical Fingerprint Sensor: 步骤 4 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor: 步骤 4 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor: 步骤 4 中的图像 3,3
    • Select the "Rename" option.
    • Delete the .jar at the end of the app's name.
    • Your file should now appear in the "Installation files" tab.
  5. How to Calibrate an Optical Fingerprint Sensor, Open the Self Repair Assistant app: 步骤 5 中的图像 1,2 How to Calibrate an Optical Fingerprint Sensor, Open the Self Repair Assistant app: 步骤 5 中的图像 2,2
    • Open the Self Repair Assistant app.
  6. How to Calibrate an Optical Fingerprint Sensor, Agree to the terms and conditions: 步骤 6 中的图像 1,1
    • Select "Agree" to accept the Terms and Conditions.
  7. How to Calibrate an Optical Fingerprint Sensor, Select the procedure: 步骤 7 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor, Select the procedure: 步骤 7 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor, Select the procedure: 步骤 7 中的图像 3,3
    • Select the "Display" icon.
    • Select "Continue" at the bottom of the screen.
    • If you want to perform a battery cycle reset instead, follow this guide.
    • Select "Start" to begin the fingerprint sensor calibration.
  8. How to Calibrate an Optical Fingerprint Sensor, Begin the fingerprint sensor calibration: 步骤 8 中的图像 1,2 How to Calibrate an Optical Fingerprint Sensor, Begin the fingerprint sensor calibration: 步骤 8 中的图像 2,2
    • Once the screen turns black, select "Start" again.
  9. How to Calibrate an Optical Fingerprint Sensor, Apply the white box: 步骤 9 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor, Apply the white box: 步骤 9 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor, Apply the white box: 步骤 9 中的图像 3,3
    • Place the white box over the outline near the bottom of the screen.
    • Cover the outline with the side on the box that matches the pattern.
    • Make sure the white box completely covers the outline. Deviations could result in a "Fail" result or an inaccurate calibration.
  10. How to Calibrate an Optical Fingerprint Sensor: 步骤 10 中的图像 1,1
    • Use your finger to press down on the white box.
    • While pressing down, use your other hand to select the "Next" icon near the top of the screen.
    • Continue pressing until the "Calibrating" disappears.
  11. How to Calibrate an Optical Fingerprint Sensor, Apply the black box: 步骤 11 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor, Apply the black box: 步骤 11 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor, Apply the black box: 步骤 11 中的图像 3,3
    • Place the black box over the outline near the bottom of the screen.
    • Make sure the black box completely covers the outline. Deviations could result in a "Fail" result or an inaccurate calibration.
  12. How to Calibrate an Optical Fingerprint Sensor: 步骤 12 中的图像 1,1
    • Use your finger to press down on the black box.
  13. How to Calibrate an Optical Fingerprint Sensor, Apply the small white box: 步骤 13 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor, Apply the small white box: 步骤 13 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor, Apply the small white box: 步骤 13 中的图像 3,3
    • Place the side of the small white box with the grooves over the inner portion of the outline near the bottom of the screen.
    • Make sure the grooves on the box are vertical when placing it on the screen.
    • Make sure the white box completely covers the inner outline. Deviations could result in a "Fail" result or an inaccurate calibration.
  14. How to Calibrate an Optical Fingerprint Sensor: 步骤 14 中的图像 1,3 How to Calibrate an Optical Fingerprint Sensor: 步骤 14 中的图像 2,3 How to Calibrate an Optical Fingerprint Sensor: 步骤 14 中的图像 3,3
    • Use your finger to press down on the small white box.
    • Continue pressing until "Done" appears at the top of the screen.
    • You may need to reset your device for the calibration to apply.
结论
Your optical fingerprint sensor is calibrated and ready for use.
If the calibration fails for any reason, repeat the calibration procedure.
40等其他人完成本指南。
Alex Diaz-Kokaisl
于01/16/22注册
161,942 声望
创作了769篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,409篇指南
22条评论
When I open the app after installation I get this toast message "this model is NOT supported"
My device is a Galaxy A71
Pierre Ehab - 回复
I have a Galaxy A70. "Fingerprint sensor Calibration needed" when I try to turn on Biometric. *# 0 *# says the sensor is alright (everything pass) But calibration = 1
HOW do I calibrate the sensor? The local samsung service center is trash
nombre20 apellido20 -
When I open the app after installation I get this toast message "this model is NOT supported" My device is a Galaxy A52
neskagu nikomu - 回复
Hi there.
Unfortunately, as stated in the introduction, the only device supported right now is the Tab S7+ . Samsung plans to include more devices with time.
Alex Diaz-Kokaisl -
It showed not supported for this model... What should i do next
Salem Ekwuribe - 回复
添加评论
浏览统计数据:
过去 24 小时: 112
过去 7 天: 673
过去 30 天: 2,578
总计 176,835
