简介
任天堂的第一批左 Joy-Con 手柄因同步问题而臭名昭著。这存在一个很小的设计缺陷,可以用一小块导电泡沫来补救,这种泡沫在家里的旧包装中就能找到!
你所需要的
视频介绍
结论
要重新组装设备,请按与说明相反的顺序进行操作。
12等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
7指南评论
What thickness of conductive foam should I choose? There are 3 sizes: 3mm/0.12, 5mm/0.20", 10mm/0.39"
maximaleks - 回复 分享
The space is ~9 mm wide, so I would go with the 10 mm size and you can trim it down if you need to!
Taylor Dixon - 回复 分享
I've got the same problem but with the right joycon but I don't know where the wireless card is, please help
Nathan Currie - 回复 分享
Hello I opened up my left joycon and saw conductive foam inside already! I replaced it with one that I bought on amazon (I made sure it was actually conductive foam). But it still won’t sync. Any ideas? Could it be that little solder bubble that connects to the antenna has gone bad? Should I try to reflow it? I also checked to see if any capacitors in the top of the board were shorted and none of them were. If you have any ideas I would be happy to hear!
Chaim Bendahan - 回复 分享
I opened my left Joycon and found that there is no antenna area near the joystick compartment. It’s just an empty space what should I do, I have the conductive foam but obviously don’t know where to place.
Omar Gonzalez - 回复 分享
