简介
本指南将指导您如何为您的哈雷戴维森Sportster更换传动油。
Evolution Sportsters具有湿式离合器和主离合。建议在1000英里时换油,然后每10000英里更换一次油。
制造商建议使用20w50油。 请确保您所使用的油是能够在离合上使用的油。 所以我们建议您购买专门为摩托变速器使用的特别配方的油。 在本指南中我们使用75w90齿轮油代替20w50机油。
你所需要的
使用 使用 5/32"六角扳手 或六角螺丝刀, 拧下主链检查盖上的两颗螺丝。
您的检查盖可能不是圆的,这取决于您机车的生产年份。 不论如何它将处在相同的位置并使用相同的螺丝固定。
将主链检查盖从变速箱上取下。
82等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
35指南评论
but you CANT use gear oil for cluthc!!!
car motor oil CANT be used for bike cluthc!!! Motorcycle motoroil CAN!
Is synthetic 20w50 ok to use?
Jordan -
What the !&&* is a cluthc?
redin575 -
You can use Amsoil 20w50 Synthetic V-Twin Motorcycle Oil. It is certified for engine, transmission, and primary chaincase lubricant. Manuals will specify gear oil as well (75w90), which is also appropriate to use. Note as Eric Essen wrote that these oils are defined differently. Link to the Amsoil 20w50: https://www.amsoil.com/p/20w-50-syntheti...
Sir_Nerd -
I change my my transmission oil exactly how it showed and yes the spring with the nut on the end came off and I put it right back. Now I have no tension at all in my clutch basically I have no clutch anymore. This is the first time I've taken the inspection plate off during a transmission fluid change. I usually drain it and automatically just put one quart in. What could I have done wrong?
