跳转到主内容
任天堂Switch 右 joy-con SL/SR 排线更换
你所需要的
  1. 任天堂Switch 右 joy-con SL/SR 排线更换, SL/SR 排线: 步骤 1 中的图像 1,3 任天堂Switch 右 joy-con SL/SR 排线更换, SL/SR 排线: 步骤 1 中的图像 2,3 任天堂Switch 右 joy-con SL/SR 排线更换, SL/SR 排线: 步骤 1 中的图像 3,3
    • 用Y00 三点式螺丝刀拆卸背板的4颗螺丝
    • 在拆卸的时候,请小心放置螺丝,谨防遗失或者损坏
  2. 任天堂Switch 右 joy-con SL/SR 排线更换: 步骤 2 中的图像 1,3 任天堂Switch 右 joy-con SL/SR 排线更换: 步骤 2 中的图像 2,3 任天堂Switch 右 joy-con SL/SR 排线更换: 步骤 2 中的图像 3,3
    • 用三角撬片从底部小心分开上下壳
    • 分离上下壳的时候一定要小心,轻轻分离上下壳,不要扯断连接的排线
    • 排线很脆弱。太用力可能会导致排线损坏
    My joycon would not open as cleanly as what is pictured here. The white box at the bottom of the controller in the last picture stuck to the top compartment and became detached from the part with the battery. It's possible it could have detached the other way, but I didn't risk it. I was still able to do the repair, but it gave a much tighter window as I needed to be very careful to not be to forceful on the battery wires.
    lipolane - 回复
  3. 任天堂Switch 右 joy-con SL/SR 排线更换: 步骤 3 中的图像 1,3 任天堂Switch 右 joy-con SL/SR 排线更换: 步骤 3 中的图像 2,3 任天堂Switch 右 joy-con SL/SR 排线更换: 步骤 3 中的图像 3,3
    • 使用 00 号十字螺丝刀卸下充电导轨上的两颗 3 毫米螺丝。
    • 需要更换的部分是这两颗螺丝正下方的按钮板。
    Be careful when removing. What is not noted here, is that the SL, SR, and reconnect buttons will fall out. Just make sure you are over a table so they don't get lost.
    lipolane - 回复
  4. 任天堂Switch 右 joy-con SL/SR 排线更换: 步骤 4 中的图像 1,3 任天堂Switch 右 joy-con SL/SR 排线更换: 步骤 4 中的图像 2,3 任天堂Switch 右 joy-con SL/SR 排线更换: 步骤 4 中的图像 3,3
    • 使用 00 号十字螺丝刀卸下电池盒上的三颗 3 毫米螺丝。
    • 拆卸电池模组边上的螺丝之后,更换SL/SR排线会更方便
    En la imagen se realiza sobre el Joy con derecho, si es el izquierdo, solo será un tornillo en la parte baja, se despega la batería y se sacan los dos tornillos de la chapa
    Daniel otero ambroa - 回复
    I must have had a different model because there weren't any screw near the trigger on top of the battery for me. Those screws were located under the battery, which you can lift up (it is a little sticky). To do this on mine, I had to detach the rail from the lid in order to give myself enough clearance to lift the battery out.
    Originally, I tried to do the next steps without lifting the battery compartment, but it was too difficult to mess with the locking mechanism on the ribbon.
    lipolane - 回复
  5. 任天堂Switch 右 joy-con SL/SR 排线更换: 步骤 5 中的图像 1,3 任天堂Switch 右 joy-con SL/SR 排线更换: 步骤 5 中的图像 2,3 任天堂Switch 右 joy-con SL/SR 排线更换: 步骤 5 中的图像 3,3
    • 用塑料撬棒打开插排座子的卡扣。 轻抬电池模块,使得有更多空间操作SL/SR排线的拆卸
    • 打开卡扣后,取下弯曲的排线。
  6. 任天堂Switch 右 joy-con SL/SR 排线更换: 步骤 6 中的图像 1,3 任天堂Switch 右 joy-con SL/SR 排线更换: 步骤 6 中的图像 2,3 任天堂Switch 右 joy-con SL/SR 排线更换: 步骤 6 中的图像 3,3
    • 将新的SL/SR排线插入插座
    • 用塑料撬棒协助插入之后,重新锁上卡扣
    Die Lasche ist bei mir sehr locker. Das Kabel rutscht immer wieder raus, fixiert die verriegelte Lasche für gewöhnlich das Kabel? Ist die Lasche bei mir defekt?
    Bobo - 回复
    I can’t this to lock in to place any ideas on who to get it to work
    bubbles290784@yahoo.com - 回复
  7. 任天堂Switch 右 joy-con SL/SR 排线更换: 步骤 7 中的图像 1,3 任天堂Switch 右 joy-con SL/SR 排线更换: 步骤 7 中的图像 2,3 任天堂Switch 右 joy-con SL/SR 排线更换: 步骤 7 中的图像 3,3
    • 为了防止以后出现相同的问题,确保排线正确并且牢固的弯曲的组装在电池模组下面
    • 轻轻提起电池模组,以便于在其下方弯曲新的按钮板排线。
    • joy—con的电池模组和背板之间的组装很紧密,没有多余的空间,这导致SR/SL排线很容易扭折和损坏。相比下,将排线放置在电池模组之下会有更多的活动空间
结论
需要重新组装设备,请从第4步开始,按照相反的说明顺序进行操作
68等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
18条评论
Valuable step-by-step guide plus pictorial samples. Keep writing your good stuff, Javier!
Rudi Lim - 回复
Nice guide. To loosen the battery compartment on my controller I had to remove te battery first. I couldn't see te top 2 screws in step 4. The battery was sticked to the bracket with some tape but removes easily. Underneath the battery were two screws.
Edit: maybe its different because I had to change the button board on the left JoyCon.
Stefan Haarman - 回复
Yes! This Guide above shows the right Joycon. As for the left one there are two screws below the battery as you said!
Paul Stachowiak -
Very helpful step-by-step guide. Thank you.
Had to change the Button Board on the left Joy-con. The screws were also located under the battery in my case. Attention: there 4 screws under the battery, two of which diagonal to each other that hold the battery compartment in place. No need to unscrew all 4.
Tone - 回复
I’ve replaced the board, but SL and SR still not working, also two lights not working. What to do?
Mike - 回复
Will this replacement also fix the LED lights that are now not working on my controllers? And if not, will this be a problem for playing with one Joy-con?
Sofie Lazeroms - 回复
Depends on why your LED´s are not working. For my it was because the SR SL input was not registered, which will be a problem (only) for single joycon use. If its only the LED which is not working, then you should be fine.
Paul Stachowiak -
Thanks for spreading this knowledge to us.
Nolan Lester - 回复
Thank you! My right button on the side turned unresponsive. I replaced the button board with this guide and fixed it!
Bouw De Vrieze - 回复
Great guide - thank you. i need new eyes though... can barely see the screw heads!
Matt Glover - 回复
I followed this guide, the LEDs, sync button and charging all work again, but the sl sr buttons still don't work
Julie - 回复
Mega, nach dieser Anleitung funktioniert der Joy wieder einwandfrei 💪🏼👍🏼.
Andreas Kaiser - 回复
Excellent guide, thanks!
I also had a left joycon, so thanks to everyone who commented about the difference with the battery screws.
After I closed everything, i could feel the battery moving inside, I think it'd be better to stick it in place woth some tape.
Also, the hardest part for me was stel 6, inserting the new cable into the tab. I couldn't make it stay inplace. Then I broke the black tab lock. But finally I managed to put the cable into the tab, fold it like described and close the battery compartment, and the cable stayed in place.
The joycon works! I hope that shaking the joycon won't free the cable as nothing is locking it in place except for the cable tension due to it being folded.
Assa - 回复
Just used this tutorial today to fix my left joycon, thanks for the tips! One thing I’d also recommend is reinforcing the part so the SL and SR buttons are more clicky. To do this, I took the old, faulty part and ripped off the ribbon cable, then used a knife to remove the electronic parts from it so it was just a flat board of the exact same shape. I then screwed both in together one on top of the other, so that the part didn’t flex as much when the buttons were pressed. It’s now more clicky than the original board, which is nice! The piece flexes less too so less prone to breaking.
Wex - 回复
Thank you for the guide Javier! Thought my luck had run out when my OG joycons stopped working individually, but this guide and parts saved them! 7 years strong and going.
Definitely recommend folding the cable under the battery. It can feel tight because the new boards' cables come super straight, but just fold it over as much as you can and press the battery down on top. No matter how hard you press the battery the space stays quite big for them so just keep it in place while you screw it back in
Salucks - 回复
The guide is incomplete. It should include a 'how-to' section for the left Joy-Con as well, since the steps are different enough to cause confusion.
Raul Adrian Izarraras - 回复
Should have read other people's comments before changing the left Joy-Con board :) Still, great guide!!!
ShelfCrit - 回复
Bought a used switch with broken sync/SR/SL ribbon on both joycons, fixed them thanks to this tutorial and the parts bought in the ifixit store, used @Tone method for the left joycon.
Great tip to set the ribbon under the battery compartment.
rbfr31 - 回复
添加评论
浏览统计数据:
过去 24 小时: 66
过去 7 天: 634
过去 30 天: 2,740
总计 113,555
