简介
按照本指南的操作来更换Switch的扬声器。
你所需要的
若要重新组装设备,倒序按照本指南操作。
22等其他人完成本指南。
由衷感谢以下译者:
27%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
6指南评论
Will typical PC thermal paste work? I have a lot of that lying around and I don’t want extra cost (already spending the price of the speakers for the tools alone).
Nico Robin - 回复
Has anyone tried to change the speakers for better ones? And how would that be done?
I just completed this as my first repair to anything, and it was surprisingly simple & easy! I was worried about the connections not working, but everything worked like a charm!
What do you do if the white connector on the motherboard, where you would connect the speaker, has snapped off? Is there any way to reconnect it?
It sounds like the part that you use to connect the speakers to the motherboard has seperated. This would require microsautering, which is very complicated and difficult to do. I would take it to someone with microsautering experience, or just not use that speaker if it doesn’t bother you. Unfortunately, there isn’t much else you can do about it.
Hope this helped.
Ember -
