跳转到主内容
三星Galaxy S5——移除锁屏密码
视频概述
  1. 三星Galaxy S5——移除锁屏密码, 三星Galaxy S5——移除锁屏密码: 步骤 1 中的图像 1,3 三星Galaxy S5——移除锁屏密码, 三星Galaxy S5——移除锁屏密码: 步骤 1 中的图像 2,3 三星Galaxy S5——移除锁屏密码, 三星Galaxy S5——移除锁屏密码: 步骤 1 中的图像 3,3
    • 如果你忘记了锁屏密码或锁屏图案,有三种方式解除锁定:
    • 你可以通过绑定在这个手机上的Google账户来解锁手机。这需要手机已经连接到一个之前已经连接过的WiFi网络。
    • 如果你以前创建过的话,可以输入备用密码。
    My WiFi is off on the mobile so I can't hav access to internet on it
    Christine Meunier - 回复
    Trying to unlock my galaxy s5
    how to access google account by phone when it is locked?
    sanjivmehan - 回复
    That is what i need to know...it is asking for passcode to get into google as well.
    Kim Langley -
    Ever figure this out?
    Robert Gabsa - 回复
    I trying to unlock my phone I forgot it
    evangelistpetrusscott - 回复
  2. 三星Galaxy S5——移除锁屏密码: 步骤 2 中的图像 1,3 三星Galaxy S5——移除锁屏密码: 步骤 2 中的图像 2,3 三星Galaxy S5——移除锁屏密码: 步骤 2 中的图像 3,3
    • 关闭手机。
    • 同时安装音量+键、Home键和电源键。
    • 当Galaxy标志出现时,松开电源键,但继续按住音量+键及Home键。
    • 出现Android系统恢复界面是,松开所有按键。
    • 使用音量+/-上下移动,按下电源键代表确认。
    • 选择 ”wipe cache partition“(清除缓存分区),”Yes -- delete all user data“(是的,清除所有用户数据),“reboot system now”(立刻重启)。
    • 完成。
    • 请关注我的Youtube频道 ツ
    Didn't work didn't give me option to delete all user data
    dthompson0916 - 回复
    Me too and I've tried it so many times that I remember my password now! Lol
    So I guess it workd in a sense
    missfesterfan -
    I have done reset my phone to the factory setting as I forgot the Samsung account password. After resetting, tried to activate the phone again, but is still askes for Samsung account ID & password :(
    Does anyone has any solution????
    Thanks
    J Kurd - 回复
    Is your samsung s5 fixed already??got same problem too..i forgot my samsung id
    kathzeemeaow -
    how to reset my mobile question
    muhmmadjaved603 -
    having same problem, i dont ever remember having a samsung account and it has no id for me when i enter my info. This step was never indicated on all the info i looked at regarding a factory reset following this horrible lollipop update
    Janice Lampkin - 回复
    this worked for me perfectly ...thanks guys am really happy.
    ogwalrobine - 回复
    Didn't work. I'm a truck driver, need my phone!
    donnamarie816 - 回复
    You have to use the factory reset option if you forgot your password. Then i just bailed out of all the signing up for all the crap and got to the home screen, and now the phone is unlocked and no password.
    rpeterson64 - 回复
    but did you lose all your pictures and contacts?
    elmolover88b -
    Didn't work I have a galaxyon5 from metro pcs
    Timothy Lang - 回复
    it hasnt worked for me either... it randomly removed the print scanner last night / this morning and i can´t get on it
    skelseyzl9 - 回复
    I brought my s5 , 2 years ago second hand how do i remove the previous owners samsung account obviously i dont have there password .
    TIA
    jenjen85 - 回复
    Mine does not even turn on up to the Samsung logo when pressing all three buttons
    Terence - 回复
    didn't work although I did everything
    proberts2020 - 回复
    i did this successfully but my up & down vol button didnt work, its like the screen freezez?
    i did this successfully but the screen freezez My vol buttons dont go up & down, they work perfect otherwise, can any1 please help me?
    a.doupis - 回复
    Worked wonders thank you very much
    Christine Whitmire - 回复
    If it's asking for samsung password then go to samsung.com because either the previous owner or you when you got your phone registered this device through Samsung for warranty purposes. Once in samsung.com you can call chat or enter
    Any email addresses you've used since you've had the phone. The email address is username and if it recognizes any of those then you can simply reset your password and that's what you will use on your phone. Otherwise just call samsung.com give them your IMEI number for them to pull it up and they can reset it the password for you. That the factory reset instructions above does work. I had to do it about 3 times because I either didn't have all three buttons held at the same time or accidentally let off of one without realizing it or didn't let off of the power button when I should had. Once you get to the reboot page there are two different options for wiping data definitely pick the one that is wipe all data factory reset.
    Cass - 回复
    If it freezes take the battery out about 10 seconds put it back in but do not turn on the phone. If it's still stuck on the same screen wait about 5 or 10 minutes and it will go off it may take some time. Try the factory reset steps above again. It works it just may take a few times and you will have access to your contacts and pictures if you have been saving them to some sort of cloud or Google account and if there is a Samsung account your contacts are definitely stored and other data will be too. Unfortunately I had to do this and was worried everything would be gone but Google backed everything up except some of my photos but my phone ran so much faster afterwards so it wasn't a complete loss
    Cass - 回复
    I would like to say happily , it worked first time I tried - following instructions to the letter! Surprisingly, all my pics and messages etc are still on the phone! Plus I did it without taking the battery out or anything.Thanks
    Elaine Hunter - 回复
    All you need to do is start up in safe mode and there will be a password reset at the start up. To go into safe mode hold your power button until the Samsung logo pops up then release and hold volume down button until your start screen pops up then you're in safe mode.
    Travis Pierce - 回复
    Great Worked first time Thankyou
    Trish - 回复
    hi my phone lock went samsung account help me openit
    ravendra - 回复
    hi phone lock went samsung account place help me
    ravendra - 回复
    Hallo habe den Reset gemacht und jetzt zeigt es mir nur das Samsung Logo an und ladet wie lange könnte das dauern in etwa ????
    Sascha Egger - 回复
结论
若要重新组装你的设备,按照以下步骤逆序操作。
199等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
ZFix
于12/09/13注册
194,051 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
327 名成员
创作了1,697篇指南
49条评论
Very easy steps to follow, and it worked perfectly. Life saver, thanks a lot.
Scootie - 回复
To remove your screen lock on Samsung, this article gives three methods:
Lucious Nicole -
I did a factory hard reset, and it requires me to enter my samsung account information. I know what that information is, but for some reason samsung has no record of me! I don't think it will do me any good to re-do the factory hard reset. I'm being told I now have a paper weight. Any other ideas to bypass this?
Penny Maurer -
@Penny, if you can’t use this way to unlock Samsung phone password, you can try another method to unlock Samsung phone password, with Samsung Unlock, you can unlock Samsung password in several clicks, and detailed guide, easy operation.
Salim -
I have a samsung account but my phone has mobile data and wifi switched off! what can I do, I don't want to do a reset.
amy cross - 回复
I also have this problem! What can i do??
Gm Allians -
Instead of wipe cache partition, you the factory wipe choice above it and it will give the option of yes
yingsuhe - 回复
Is there a way to get into the phone without losing the data that's already on it. I'm trying to get access to text messages?
jarrodroberts22 - 回复
me too Its really annoying that I forgot my password after all these years
InfoDCook -
You can also enter the wrong pin 10 times. The phone will erase and return to factory reset.
gasstationman2 - 回复
You can also enter the wrong pin 10 times. The phone will unlock, erase, and reset to the factory settings.
gasstationman2 - 回复
not always, you would have to manually turn that on. when i had my IPhone I turned that off so that would not happen
Aspen McBride -
Will I loosen min contacts on my online carrier website as well how can I keep my contacts if I reset it
tj Ellison - 回复
I have traded my phone for a galaxy5s but I do not know what the password is
Tiffany Taylor - 回复
After selecting the option"reboot now" the phone asks to "choose a package to install:/cache/recovery" ....now what am I supposed to choose???
shamsulhaque517 - 回复
Easy, but hate losing all my info.
nnadeb - 回复
This works perfectly, thanks.
Sincere Ceo - 回复
Thx so much i had to reset 3 accounts but it was so worth it
badbae 101 - 回复
how much data will i loose?
Sheherbano Abbas - 回复
Thanks! Just perfect!
mirama17 - 回复
Hello,
Please I have issues with my Phone
Samsung Galaxy S5 - he screen is broken and is black now , it's no longer displaying. The screen is locked.
The phone is till turning on as it vibrates and make sound when text messages comes in.
Please how will I be able to copy my data out with the above conditions?
Shade
Shade - 回复
my s7 is doing the same smh
InfoDCook -
Pero luego de eso recuerda que hay que ingresar la cuenta de Google. Y sino la recuerdas tienes que hacerle bypass, yo lo hago con OTG y el apk instalado en una USB es bastante sencillo y lo eh probado hasta con el S6 edge. Igual gracias por tu aporte
Manuel Cifuentes - 回复
Samsung Lock Screen Removal, which is an all-in-one data recovery tool for almost all Samsung Galaxy devices. With the help of this program, you can not only restore the lost and deleted content like photos, videos, contacts, call logs, messages, WhatsApp chats and more from your Samsung Galaxy device including Samsung Galaxy S/Note/A/J/ON/Tab, but also one click to fix a bricked Samsung and unlock your Samsung Galaxy S/Note/Tab without losing data.
So, you can easily bypass Samsung Galaxy S5 lock screen fingerprint, PIN, pattern and password by using this tool without losing data.
Video Guide: https://youtu.be/OeIFOqLx9J0
lineking - 回复
no command? whats the meaning of this? my phone hasn't back up yet
seng park - 回复
Samsung Galaxy Frozen on Startup? Here Is the Solution.Please learn the guide about How to Fix a Frozen Samsung Galaxy
https://www.android-iphone-recovery.com/...
Remove Samsung Locked Screen without Password
KIKIMAY - 回复
Bypass Samsung Lock Screen Pattern, Pin, Password and Fingerprint
vibershare - 回复
Hi, did the reset with the buttons, worked a treat, many thanks.
George Georgiou - 回复
please help me my Samsung j5 I see the screen DOWNLOADING DO NOT TURN OFF TARGET...what should I do? even I try to off can't work
Ana rose helado - 回复
please help me my Samsung j5 can't work even I turn off I see in the screen DOWNLOADING DI NOT TURN OFF TARGET..what should I do?
hi i don"t want to lose my data and i forget my password on galaxy S5.
do you have any solution?.please inbox me through eyetade@gmail.com
kalebtadele - 回复
i have samsung s5 and i forgot private pin protection. how can I get it. Thanks
aggrey209 - 回复
Hi, to remove Samsung password ,screen lock, read it :https://www.mobiledic.com/android-topic/...
Tamseerty - 回复
I've done this and it's just saying Samsung what do I do now? It's taking forever to load now? If it will ever load? I've wiped it like stated but now the phone won't go past Samsung x
leanne barrett - 回复
I forgot my password of Samsung galaxy e5 which I was set on display high security password so plz help me for break my password without reset of my all data of my phn so help me for unlock my phn screen lock
Gini - 回复
I forgot the PIN of my Samsung Galaxy j1 mini
please Help me to fix this problem
znen12 - 回复
Help please my son has locked me out of my Samsung phone it has pictures of my late dad on it so I don't want to wipe it please help
Karen - 回复
As you may be very clear that factory reset in recovery mode or Google Find My Device can result in data loss, for they need to erase your device. Certainly it will be a big headache to you that lose any important data. Luckily we have another alternative to bypass your lock screen which will not lose any data in your Samsung.
Android Lock Screen Removal is a worthy toolkit for your Samsung device to bypass screen at any time under any cases. Follow the guide to unlock the screen without hesitation.
https://www.forecovery.com/unlock-androi...
KaylaDavis - 回复
my samsung bold has been stolen and i purchased a samsung 5 with same number same contract and it requires my password and i dont remember it?
elsathursfield - 回复
Works greatly, thanks for your help. Simple steps to follow and it actually works, just finished unlocking my forgotten password.
ope726 - 回复
What if you need access to your fingerprint scanner but can't remember backup pin
creative name - 回复
I really appreciate you guys for
This site has really helped me tremendously
Farnue - 回复
Boop boop boop boop it works lol lol lol
Destinee Champs - 回复
Galaxy S5 mini : aucune fois ne propose de pouvoir se connecter sur Google avec son compte, le téléphone dit d’attendre mais ne propose rien de plus. Après, j’ai tenté le reboot usine, avec les boutons différents expliqués ci-dessus. Echec sur échec, donc toujours bloqué ! C’est un portable qu’on m’a filé mais la personne ne se souvient plus de son mot de passe et a changé ses identifiants google… Résultat : un tel qui ne sert à rien, et je déteste le gâchis ! ça ne fonctionne pas du tout, aucune des étapes ne fonctionnent !
nicolasdurand22 - 回复
hola una pregunta al hacer esos pasos , también se borran los documentos guardados, en el teléfono??? contesten no quiero perder mis archivos
emirnoe2.0 - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 106
过去 30 天: 405
总计 803,573
