简介
本指南教导如何移除和更换三星盖乐世 S20 Ultra 的无线充电线圈。
你所需要的
在手机背面尽可能靠近左边缘的中心放置一个吸盘,用稳定的力拉动吸盘。
插入后盖和框架之间形成间隙。
由于此边缘上的玻璃是弯曲的,因此你无法将此三角撬片插入很远。
你也可以尝试在接缝中滴几滴高浓度(超过90%)的异丙醇以帮助软化胶粘剂。
将新的更换零件与原始零件进行比较 - 在安装之前,你可能需要转移剩余的零件或从新零件上取下粘性衬板。
要重组设备,请按逆序执行以下说明。
在完成本指南后,请校准你新安装的电池。
将你的电子垃圾带到R2或e-Stewards认证的回收商。
修理没有按计划进行?查看我们的论坛以获取故障排除帮助。
要重组设备,请按逆序执行以下说明。
在完成本指南后,请校准你新安装的电池。
由衷感谢以下译者:
75%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
2条评论
Hi,
I had my s20 Ultra run over by a vehicle about a year ago and I'm going to purchase some parts from here with these awesome tutorials!
Do I need to have a wireless charge coil for it to function? I'm just looking to use my hopefully repaired s20 ultra as a mini PC by using Samsing Dex because I bought the 512gb model with 16gb ram. I can't let all these good and expensive parts go to waste. The wireless charging isn't important to me for these purposes.
Thank you,
Russell
Hey
The S20 ultras wireless also includes NFC and a coil specifically designed for Samsung official lines of their very own cases, (s view, led)
Other than that if you dont mind having nfc, wireless charging or compatibility of those cases then you are good to go.
Eden Jeong - 回复
