简介
使用本指南更换三星盖乐世 A3(2017)中的电池。
打开三星盖乐世 A3(2017)手机。将损坏设备上的防水密封。如果你不更换粘合剂密封件,你的手机将正常运行,但它将失去防水功能。
如果你的电池膨胀,请不要加热手机。膨胀的电池可能非常危险,因此请佩戴护目镜并保持谨慎,或者如果你不确定如何继续操作,请将其送到专业人员手中。
重组设备时,你需要使用更换粘合剂重新安装电池和后盖。
你所需要的
要重新组装设备,请按逆序操作。
如果可能,请在安装新胶粘剂并重新密封手机之前打开手机并“测试维修'。
'''用预先切割的粘合剂或双面胶带固定新电池‘’‘’并将其牢固地按压到位5-10秒。
为了获得最佳性能并避免出现软件错误,请校准新安装的电池:将电池放电至10%以下,然后将电池不间断充电至100%。
18等其他人完成本指南。
由衷感谢以下译者:
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
5指南评论
La batteria nuova,presenta la protezione, ovviamente tolta ma rimane ancora la colla
Immagino vada tolta per consentire di fare contatto con il display tack??!
Ho sostituito la batteria al mio Samsung a3, sul retro vi è resto di colla dovuta alla protezione. Immagino vada tolta per far contatto. Giusto?
Very instructive and easy to follow battery replacement guide!
CSD
Unfortunately I had no iOpener or proper spudgers at my disposal, so I found that a pretty thin and flat plastic (!) spatula and a hairdryer also worked. The spatula was about as wide as the battery and fit perfectly in the pocket near the bottom of the phone and the battery. A bit of gentle heat from the hairdryer and by using the spatula as a lever the battery popped out in no time.
Hi, My Samsung Galaxy A3 2017 gets hanged while running and shuts down while two buttons stay lit for a few seconds then totally shut down and I have to start it with volume down and power button, or else it doesn't start. It happens many times in a day. can this be a battery issue? Also sometimes the first system doesn't work too then I disconnect the battery and connect it to the charger then I disconnect the charger and connect the battery and if I press the power button it starts again. Can this be a battery issue? Any idea? Thanks in advance.
Harry Potter - 回复 分享
