简介
如果你的一加6T遇到电池电量问题或者无法充电,那么可能是时候更换手机电池了。
要重新组装你的手机,请按相反顺序操作。
要重新组装你的手机,请按相反顺序操作。
17等其他人完成本指南。
特别感谢这些译者︰
66%
Nero Hu正在帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
9条评论
Does the adhesive for the back cover need to be replaced? Should I heat the phone and back glass for re-assembly?
Good questions. I think “reassembly is the reverse of these instructions" is a bit simplified. I think the heat is only for removal, but perhaps it would cause the adhesive to rebond after reassembly? Can an ifixit tech comment?
Just wondering if anyone can clarify the reattachment of the rear panel, as far as whether it is recommended, or necessary, to heat it again, or get a new adhesive gasket. Thanks.
Good question! You should replace the back cover adhesive with either a custom-cut adhesive or double-sided tape such as Tesa tape. You can choose to reheat and reuse the existing adhesive, but there may be a chance that the back cover will fall off. If you’re reusing adhesive, be sure to remove any uneven adhesive chunks.
What width Tesa tape would work for the replacement of the back cover?
