跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
更换三星盖乐世S8的背部玻璃后盖
你所需要的
  1. 更换三星盖乐世S8的背部玻璃后盖, 玻璃背板组件: 步骤 1 中的图像 1,1
    • 在S8 的背面较长一端放置加热过的iOpener 大约2分钟。
    • 拆开手机会破坏防水密封。 在继续之前准备好更换粘合剂,如果你在没有更换粘合剂的情况下重新组装手机,请注意避免接触液体。
    • 加热 iOpener 并将其贴在 S8 的长边上约 2 分钟。
    • 你有可能要多次加热iOpener以及将iOpener放置在手机上多次来加热下方的粘合剂。 按照iOpener指南来避免过度加热iOpener。
    • 也可以使用吹风机、热风枪或热板,但要小心不要让手机过热——OLED 显示屏和内部电池都容易受热损坏。
    • 当您在等待粘合剂软化时,请继续阅读以下步骤以了解在何处撬动。
    What type of adhesive should be used to seal? Or better said, what would you recommend.
    Ion Ion - 回复
    I’d recommend precut adhesive designed for the rear cover. If that’s not available, thin, hi-bond double sided tape like 1 mm wide Tesa 61395 tape will work well.
    Adam O'Camb -
    Yes, different microwaves have different power levels (e.g., wattage) so one microwave may explode the iOpener after 31 seconds of heating whereas another microwave will barely warm it. It would be helpful to have a more precise target temperature. My microwave is fairly weak so I’m heating it for seven seconds for every two minutes against the phone. In theory, this should slowly add more heat than is dissipated into the phone and surrounding atmosphere.
    Brett Stime - 回复
  2. 更换三星盖乐世S8的背部玻璃后盖: 步骤 2 中的图像 1,2 更换三星盖乐世S8的背部玻璃后盖: 步骤 2 中的图像 2,2
    • 接下来的步骤中将切割背面玻璃面板边缘下的粘合剂。
    • 后壳上的粘合剂如第一张图像所示。
    • 从手机外面看到的撬动位置如下:
    • 厚的粘合剂部分
    • 较薄粘合剂的部分
    • 为了保护指纹识别传感器,避免撬动这里。
    Go clockwise (or counter-clockwise) around the border to avoid causing extra stress on the back. The bottom has a lot more adhesive than you think, towards the top-center.
    Michael M - 回复
    Failing completely at this step. I’ve heated the opener like 5 times and the phone is hot to the touch, but I can’t get even the tip of the pick into the opening.
    r torrance andrews - 回复
    Added a hair dryer to the effort and stil making no headway at all.
    Be careful. Insanely careful. If you think you are careful enough, this means you need to be even more careful. If you think it is not possible to be more careful, then be a little more careful and you might be able to remove the back cover without breaking it. Especially the bottom of the phone.
    pio - 回复
  3. 更换三星盖乐世S8的背部玻璃后盖: 步骤 3 中的图像 1,3 更换三星盖乐世S8的背部玻璃后盖: 步骤 3 中的图像 2,3 更换三星盖乐世S8的背部玻璃后盖: 步骤 3 中的图像 3,3
    • 一旦后面板摸起来感觉温暖,请在尽可能靠近手机加热边缘的地方使用吸盘,同时避免弯曲边缘。
    • 吸盘不会在玻璃弯曲的地方吸附的很好。
    • 如果手机后盖破裂,吸盘可能无法粘住。 尝试用强力胶带提起它,或者用强力胶将吸盘固定到位,这样你就可以继续了。
    • 提起吸盘,然后在后玻璃下方插入撬片。
    • 由于弯曲的玻璃,你需要按照弯曲的弧度向上推撬棒,而不是径直插入到手机里。
    We can't seem to get anything between the edges even after heating the back panel. Any tips?
    Megan Kennington - 回复
    Hi Megan, unfortunately the adhesive is super tough on this one. I’d recommend carefully continuing to apply heat, very gradually so that you don’t accidentally overheat the battery. Eventually you should be able to get a little gap with the suction handle.
    Adam O'Camb -
    I’ve been attempting to get the adhesive to loosen for four hours now. Exactly how much time is this supposed to take? The pictures makes it look like it should be easy. The adhesive still hasn’t budged and I’m beyond frustrated.
    Lori Lucas - 回复
    Hi Lori, sorry to hear the adhesive is being extra stubborn! If reheating and reapplying the iOpener isn’t working, you can try heating the edge with a hairdryer or heat gun. That way you can get more heat onto the edge faster, but be very careful not to overheat the battery inside.
    Adam O'Camb -
    I used a stanley knife - very carefully, after trying for several hours to get the adhesive to loosen. I bought another back cover with adhesive for the assmbley, which is the best option in my opinion. Just be careful not the scratch the case of the phone, and be prepared for the back glass cover to break when removing it.
    James wright - 回复
    The manufacturers really want to make this impossible, huh… I’ve gone 3 years without ever cracking this phone and end up cracking the corner of the back trying to prise it open. Probably should’ve gotten a heat gun too. This is super tight.
    Benjamin Chaim - 回复
    I am currently working on this. I have heated the phone to just barely to hot to hold. No matter how many times I've done this and pulled up with a suction cup I cannot get an edge to lift.
    Being that this is my second phone repair does anyone have advice on this? I've watched several YouTube videos and it looks so easy.
    DAVID LAWRENCE - 回复
    I suggest you try to lift on the middle of an edge using the thinnest spudger you have. also as the edge is curved remember to insert it so to follow the curve. Hopes it helps
    Cajuteq -
    Our issue was that a small gap would open when using the iOpener, but not large enough to get spudger or opening picks in there (also tried hair dryer but same result). Luckily as a guitar player I had some very thin nylon picks that we were able to get in there, which opened up a large enough gap to get the spudger and opening picks in. From there, we were able to heat the other sides and guide the spudger around the entire edge to get the back glass off.
    First we used a Dunlop nylon .38 mm guitar pick, then a .60 mm pick, and that allowed us to get the spudger in.
    Dan Coleman - 回复
    This is by far the hardest part of any tutorial that requires you to open the Samsung. The iOpener is totally useless on my opinion (it doesn’t get warm enough). What I did instead is use a hairdryer but it took me time before I could get the adhesive soft enough. Especially since I was not able to measure the temperature of the phone will warming it. Also I think that the halberd is not thin enough so I used a radiology sheet (don’t know the right word in English) to get into the phone and it was much more effective and time saving. Thank you for the tutorial and good luck !
    Thomas Alliot - 回复
    Use a utility knife blade to work around the edges. Careful not to pry on the blade since you risk cracking the back
    Derek Gibson - 回复
    I bought a back glass replacement kit with the battery kit since mine was cracked already. I used both iOpeners to uniformly heat the whole back along both long edges. I microwaved each pack twice over 10 mins. 5 mins apply, microwave, 5 minutes apply. That worked!
    William Mellema - 回复
    Similar to other posts, this appeared simpler. I have a couple of tube socks filled with rice that we use a lot for a sore back. Put in microwave for 5 minutes and an amazing heat pack. So I thought I would try this instead of the iOpener as it just was not getting the phone warm enough. Wrapped the phone in the riced-filled-tube sock for a couple of minutes, to the point where I could at least pick it up and hold it. Also, I have the full IFIXIT kit, so I pulled out the jimmy. Viola. Got right in and then allowed me to use the halberd and picks to finish it off.
    kendrickcc - 回复
    I was able to do this with the iOpener warming pad by microwaving for the suggested 30secs then leaving it on for 10 mins. repeated this process 2 more times for a total of 3 times @ 30 mins and used the suction tool and the picks to get it open. There is a considerable amount of adhesive on the tops and bottoms of the phone. So consider warming the whole phone before doing it.
    Note: if you already have a cracked back panel (like me) prior to starting the process, consider getting the replacement as the already cracked panel will crack even more as you are cutting away at the adhesive. Goodluck!
    Harry Williams - 回复
    After over an hour of trying to use heat and the suction tool loosen the adhesive and try to get an opening on one of the edges, I used the blue spudger to see if it would slip thru the edge and it did. I was able to loosen the majority of the back glass but ended up getting excited and rushing and cracked the top corner. I was able to complete the battery replacement and use the cracked back glass. I’m going to order a replacement for that and that should be easier. Lesson to be learned, if any part of the back glass is getting a little tougher to loosen, hit it with heat again just to be safe. The rest of the replacement we pretty straight forward.
    MJH - 回复
    The spudger provided in ifixit repair tool kit is not the same as the one used in this guide and can not be used in the same way as the spudger used in this guide. So I am pretty much winging it on the most critical point of this disassembly. This is extremely frustrating.
    Brent Neilson - 回复
    I’ve repaired many iphones but this was my first attempt on a Samsung. I made no headway at all on opening the case and I’ve decided to just live with the battery being kind of weak. Even with a short life, I would much rather use this phone than an Iphone.
    I've tried 5 times in over the course of 4 hours to loosen the adhesive on this phone, and it won't budge. Unfortunately this kit is useless to me
    Emily Reese - 回复
    Once I opened one edge, I heated up the other edges then just moved the pick around the entire perimeter of the phone to break the adhesive.
    Stephen Legg - 回复
  4. 更换三星盖乐世S8的背部玻璃后盖: 步骤 4 中的图像 1,1
    • 一旦工具牢牢地插入到玻璃里面后,重新加热iOpener然后将其放置在原位来软化粘合剂。
    svmesung is onoff and
    moo rayner - 回复
  5. 更换三星盖乐世S8的背部玻璃后盖: 步骤 5 中的图像 1,2 更换三星盖乐世S8的背部玻璃后盖: 步骤 5 中的图像 2,2
    • 将撬片沿着手机侧面滑下,分离粘合剂。
    • 缓慢移动,以免工具从接缝中滑出。 如果切割变得困难,请重新加热并重新使用iOpener(软化粘合剂)。
    Cracked my glass multiple times, do this very slowly and with more heat to each new area.
    Gary Mirams - 回复
    Second on cracking the back glass. Go slow and apply heat to each side before trying to pry it open.
    Adam Huber - 回复
  6. 更换三星盖乐世S8的背部玻璃后盖: 步骤 6 中的图像 1,3 更换三星盖乐世S8的背部玻璃后盖: 步骤 6 中的图像 2,3 更换三星盖乐世S8的背部玻璃后盖: 步骤 6 中的图像 3,3
    • 在手机剩下的边角,重复先前的加热和切割工作
    • 在你切割下一侧的时候请在先前的一侧放置一片撬片,来避免粘合剂重新粘连。
    Petite erreur: le guide dit iPhone au lieu de S7 :)
    Nicolas Duthilleul - 回复
    Bonjour Nicolas ! Merci pour la remarque ;-) Nous l’avons prise en compte et corrigé la traduction. La prochaine fois, n’hésitez pas à corriger directement en cliquant sur le bouton Traduire en haut à droite de l’étape.
    Claire Miesch -
  7. 更换三星盖乐世S8的背部玻璃后盖: 步骤 7 中的图像 1,2 更换三星盖乐世S8的背部玻璃后盖: 步骤 7 中的图像 2,2
    • 指纹传感器线缆与手机在后玻璃面板靠近主摄像头的位置连接。 这个线缆十分的短,在移除玻璃面板的时候也要断开。
    • 抬起玻璃时,请仔细查看以确保带有蓝色连接器的橙色电缆已断开连接。
    • 使用撬片将剩余的粘合剂切开,然后轻轻打开手机。
    • 如果指纹传感器电缆似乎卡住了或还是绷得很紧,不要继续抬起面板,在继续之前请用撬棒的尖端断开连接器。
    • 在重新组装设备的时候,为了重新连接指纹传感器电缆,首先将后盖倾斜到位,直到电缆连接器在其插座上完美对齐。 然后,使用撬棒扁平的一端将连接器笔直按下,轻轻将其卡入到位。
    • 移除玻璃后面板。
    For reassembly, if the fingerprint scanner is removed from the back cover: it’s much easier to place the fingerprint scanner in the small compartment on the back of the phone, connect it and then finally put the replacement back cover on. The adhesive on the inside of the back cover will get connect to the fingerprint scanner and hold it tightly.
    Brian Hoffmann - 回复
    I wish I saw this comment earlier because it's absolutely correct. I hope iFixit remedies this because it is incredibly difficult to connect the sensor when it's already adhered to the glass. It took me a good while and I ended up using some tape to keep the back glass aligned while I used the spudger to push blindly until it snapped into place. The only way I knew it worked was because I tested the sensor before fully sealing the glass.
    Preston Steimel -
    The NFC antenna and coil assembly might get stick to the back cover due to adhesive spreads while trying to pry the back cover to open the phone. Take a look inside to ensure the assebly has not got sticked. If so, try using a credit card like plastic to get it peeled of from back cover without breaking the assembly always paying attention to the fingerprint sensor as well.
    dcode - 回复
    Reconnecting this cable seems like it would be very tricky: how can you get the pieces close enough together to make the connection without having the perimeter adhesive start to connect the front and back? It seems like that adhesive could easily get messed up at this point.
    To remove the akku, high temperature was NOT constructive!! I used ethanol (cc.) instead and it worked in between 2 minutes. I think it´s also better to open the coverage in this way. Instead of heating it.
    Franz Gassner - 回复
  8. 更换三星盖乐世S8的背部玻璃后盖: 步骤 8 中的图像 1,1
    • 要安装新的后盖:
    • 使用镊子从手机底盘上剥离所有剩余的粘合剂。 然后用高浓度异丙醇(至少 90%)和无绒布清洁粘合区域,以便让新的粘合剂发挥最佳性能。
    • 撕下新后玻璃上的背胶,小心地将玻璃的一侧与手机底盘对齐,然后将玻璃牢牢地压在手机上。
    • 按照本指南重新安装旧后盖,或安装没有涂粘合剂的后盖。
    • 在涂上新的粘合剂和重新密封手机之前,请务必将手机开机并测试维修是否成功。
    • 如果需要,你可以重新安装后盖而无需更换粘合剂。 去除任何可能影响后盖安装的大块粘合剂。 安装后,加热后盖并施加压力以将其固定。 它并不防水,但胶水通常足够坚固以固定住。
    • 您可能还需要将相机挡板转移到新部件上。 如果是这种情况,请按照我们的相机挡板更换指南进行操作。
    Bonjour,
    Vous parlez d’ajouter de l’adhésif, comment et où le trouve-t-on cet adhésif ?
    Difficile à appliquer ?
    Cordialement,
    Stéphane
    Steph D - 回复
    Mille excuses, je viens de voir les “adhesive strips” :)
    Steph D - 回复
    I broke the rear glass trying to get all the adhesive off! Be very careful!!
    jimhunz - 回复
    Be careful with the NFC Antenna/Charging Coil Assembly. It’s covered in a black wrapping that can look like adhesive. Don’t scratch too hard with the spudger, the wrapping will come off!
    Michael M - 回复
    Hello, I appreciate that tuto, very detailed for a somewhat subtle job . Is it possible to use one of the 7000 or 8000 glues in place of the adhesive Stickers ? Thanks
    Isaac OLEG - 回复
  9. 更换三星盖乐世S8的背部玻璃后盖, 指纹传感器: 步骤 9 中的图像 1,3 更换三星盖乐世S8的背部玻璃后盖, 指纹传感器: 步骤 9 中的图像 2,3 更换三星盖乐世S8的背部玻璃后盖, 指纹传感器: 步骤 9 中的图像 3,3
    • 重新加热iOpener然后将其放在后玻璃指纹传感器上。
    • 推动指纹传感器,来使其与后面板上的粘合剂分离。
    • 如果传感器很难卸下,请轻轻地将一个塑料打开工具放置在塑料背衬的下方,以便在推动之前松开粘合剂。
    • 这样做可能损坏粘合剂无法重复使用,所以请先尝试第一种方法。
  10. 更换三星盖乐世S8的背部玻璃后盖: 步骤 10 中的图像 1,1
    • 如果指纹传感器粘合剂完好无损,可以被重新使用,但如果损坏,您应该去除旧的粘合剂并贴合上新的。
    • 取出旧粘合剂后,用高浓度异丙醇(至少90%)清洁指纹传感器的边缘,然后涂上新的粘合剂。
结论
黏好粘合胶后参考下列步骤的相反顺序重新组装你的设备。
129等其他人完成本指南。
由衷感谢以下译者:
en zh
75%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Sam Goldheart
于10/18/12注册
465,777 声望
创作了538篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
17条评论
Will the phone still be water proof after this
gavinjay - 回复
No. After the adhesive is removed, your water resistance is as gone as your warranty.
James watling -
after the rear panel is removed? ... no...
John Joiner - 回复
Nice its simple action with this tutrial
Seibors - 回复
Great tutorial, simple and straight to the point. My type of learning.
If I could add just one little thing….
I myself would have loved if you would have touched on replacing the fingerprint scanner ribbon when replacing the back glass. , I learned
None the less, you gave me knowledge and I thank you…
Alvin Thomas - 回复
it will be if you do the process 100% correctly and ensure a proper seal by applying enough adhesive at the edges (yet not too much!) at the edges and around the camera and fingerprint scanner. In theory that should do it, but bear in mind i have not tested this
Robin Bogaards - 回复
Where to buy original rear back glass?
a.voloshin - 回复
Under “parts required”, I see:
Galaxy S8 Rear Glass Panel - $90
Galaxy S8 Aftermarket Blank Rear Glass Panel $15
1. I assume I only need one of these parts, correct?
2. if correct, what’s the difference between the two? they look like the same exact part, except the $90 is Samsung branded and the non-branded is $15
Thanks everyone!
Jimmy Ng - 回复
That is correct. The non-branded one is generic. The one that says “SAMSUNG” is name brand and just costs more. You can use either one.
Albert Ayala -
What adhesive do you use ? can you recommend ? I bought one that already had adhesive on the back panel but one side raised up slightly, I could get my finger nail underneath and the gap was noticible.
Links to product would be great.
Thanks
Dave
dave - 回复
Hey Dave a the top of the guide we list the rear cover adhesive you can find in our store!
Sam Goldheart -
Thanks for the guide, was handy. Definitely needs glue to hold the new cover, fingerprint sensor and the other bit on - just ordered a B-7000.
drpotatoman - 回复
very hard and difficult to pass the spudger under the glass !!! But I didn’t abandonned I did it! thanks for the share.
SAINTE-COLOMBE Vonjy - 回复
I have learned my lesson! Edge dropped phone. Display cracked , force created a hidden micro crack in the back glass. I heated the back very well, but still that thing cracked as I was finishing. Take my advice, and anytime you work on this phone buy a new back, then just break off the current one. You will be sooo much happier. Don’t forget to make sure it comes with adhesive.
Max Reynal - 回复
The replacement back glass could use some more adhesive towards the top and bottom. It doesn’t sit as well as it should. Definitely no longer waterproof
Michael M - 回复
This does not show how to reinstall the adhesives.
Michael LaBarbera - 回复
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 89
过去 30 天: 315
总计 308,452
