跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
如何帮任天堂Wii主机更换光驱
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. 如何帮任天堂Wii主机更换光驱, 面板: 步骤 1 中的图像 1,2 如何帮任天堂Wii主机更换光驱, 面板: 步骤 1 中的图像 2,2
    • 用一个金属小铲子(小撬棍应该也可以)来拆开主机上的螺丝保护盖
    Die Abdeckungen sind geklebt, stecken also nicht.
    Ludger - 回复
    Don’t mistakenly remove the rubber case feet
    Bob Trout - 回复
    I just did. That picture could be better.
    B G -
    Thanks I almost removed the rubber feet
    Lushane - 回复
    If you’re wondering what to use for this, the main blade of a pocket knife from the corner of the plastic works well.
    Cameron Holman - 回复
    As you remove the hardware in each step, place them together on a sheet of paper and circle them with the step number.
    Tom J - 回复
  2. 如何帮任天堂Wii主机更换光驱: 步骤 2 中的图像 1,1
    • 拆掉这两颗8.3毫米的三角螺丝(注:如果你不明白三角螺丝的含义,你可以参考奔驰车标的样子),它们藏在你刚刚拆下的盖子下面
    Before you start, get a small plastic tray with at least 15 small bins in it, and put the screws you take out in each step in the bins in order. It makes reassembly a LOT easier.
    larry - 回复
    NOTE: You need a Y1 screwdriver. Be careful when buying the little red screwdrivers on Amazon that claim to fit the Wii - they don’t!! From personal experience.
    Robotai - 回复
    Just to add to Robotai’s comment, if you do get the little red/orange screwdrivers on Amazon, file off the tip. It if’s mostly blunt, it fits the tri-wing screws much better.
    jeff - 回复
    1/16 x 1 craftsman Phillips mini screwdriver works for this if you don’t have the tri-wing driver
    grace nicosin - 回复
    How do you make one ? If you don’t have the screwdriver
    Ethan - 回复
    I am using a 18ct empty egg carton to hold the screws/parts removed in the steps.
    karenmparamore - 回复
    Larry’s idea about the bins was great and helpful.
    Robots is right- you NEED a Y1. Just buy the thing with the drive. I didn’t, tried many other options, none worked. Had to order the thing separately with shipping. Mistake….
    David Ryan - 回复
  3. 如何帮任天堂Wii主机更换光驱: 步骤 3 中的图像 1,1
    • 拆下靠近手柄连接端口附近的一颗5.9毫米的十字螺丝
  4. 如何帮任天堂Wii主机更换光驱: 步骤 4 中的图像 1,1
    • 用刚才的小铲子移除光驱开口的橡胶垫片(注:在Wii的商标下面)
    All of the rubber feet on my very old Wii had literally melted into a gooey mess and just needed to be scraper off and cleaned with alcohol.
    Bob Robins - 回复
  5. 如何帮任天堂Wii主机更换光驱: 步骤 5 中的图像 1,1
    • 拆掉一颗5.9毫米的十字螺丝,它在你刚刚拆掉的橡胶垫下面
    please help! my lil sis got a disc stuck in my wii while it was off!!! please help fast!!!
    Leah Vegan - 回复
    It won’t come out, it will turn and go up but it won’t go fully out
    Mmbb - 回复
  6. 如何帮任天堂Wii主机更换光驱: 步骤 6 中的图像 1,2 如何帮任天堂Wii主机更换光驱: 步骤 6 中的图像 2,2
    • 小心的把Wii的面板拉开
    • 用镊子把LED的排线从主板拔出
    • 移开面板
    surprisingly, this was the trickiest step for me. I almost completely mangled the wires when my tweezers slipped as I was attempting to remove the connector.
    rbelknap - 回复
    I removed it with a spudger, gently lift from each side until it pops out.
    For those reassembling
    line up the pins push it in with your spudger gently until it's in. Then line up the front plate, push gently, confirm everything is where it should be and push firmly, I found it needed a strong push to sit flush with the other body panels.
    James middleton -
    I ended up using needle nose pliars on this step.
    Awesome detailed guide made this very easy, thank you author!
    Glenn Woodard - 回复
    Can someone direct me to what I need to do? My tweezers slipped and I cut one of the wires on the connector. Where can I find a new Y plug for the wii?
    jaredslaweski - 回复
    I also broke my wire trying to use tweezers. I should have known better. I use (normally do) a spudger on one side and my fingernail on the other to gently pry these types of connectors out. I ended up buying a replacement faceplate on ebay.
    Tyler - 回复
    This was the hardest part for me. I tried using my fingernails, two different tweezers, and needle nose pliers, but I ended up cutting both the wires. Anyway, I put some electric tape over the exposed wires and just reassembled the system. Funny thing is that the LED still works and I have not noticed any difference. I'm not sure what those wires did, but they seem to not be important.
    Nick - 回复
    For people still wondering after all these years, :), The connector is for the blue leds around the dvd when loading and unloading a disk.
    Niels -
    I also broke off the flimsy wires at the connector. To NOT break the wires, alternate pressing on the right and left sides of the connector with a small flathead screwdriver. Be patient, it will eventually work itself free. There isn't enough to grab onto with the tweezers and you'll only succeed in having them slip off, grab the wires, and yank the wires out.
    Good news is that if you do rip out the wires, no worries... I didn't reconnect them and the unit works just fine. I have no idea what those wires are even for. Power LED continues to work no problem.
    jasendorf - 回复
    I used two small flat head screw drivers, one on each side to pry out the connector. This created less pressure from me and reduced my chance of cutting the wires.
    mulkey - 回复
    This guide is really marvellous - works a treat. But I would definitely recommend needle nose pliers for this step rather than tweezers. It's really easy if you use pliers and potentially damaging if not, and you get it wrong. I had one sniff at it with tweezers then immediate nipped out to the garage for my pliers!
    thepitcanary - 回复
    Definitely a tricky step with that connector. I also cut broke the wire accidentally and was going to just give up trying to fix the Wii. However, as others stated the Wii works just fine, including the lights. I do wonder what those wire are for.
    darcaesar - 回复
    I also had a lot of trouble trying to get the connector off with tweezers. Ended up leaving it attached. It does not really get in the way of remaining steps.
    Ron Even - 回复
    Needlenose pliers did the trick for us!
    Ron Cormier - 回复
    Needlenose pliers did it for us!
    Ron Cormier - 回复
    You can save yourself some trouble at this point and skip the rest of the disassembly: See that green tab to the left of the sd card slot? THAT’S the wifi board (and that green tab, in hindsight, seems designed to make it accessible without taking apart the whole device, don’t you think?) A little careful spudging, and you’ve got it out, ready to replace! (There’s a guy who shows the process on youtube, if you want to review first)
    Will - 回复
    I got the connector out ok thanks to the suggestions here, but I couldn’t figure out how to reattach it. In the end, I just kind of threw it in and it worked fine.
    Christine Wittmer - 回复
    Very clear instructions - thanks! Faceplate needed replacing after one of my son’s friends accidentally kicked it across the room. $10 bucks to fix, thanks to ebay and these instructions. I’d never heard of a “tri-wing” screw before.
    LInda Rawlins - 回复
    I just left the connector alone and kept it connected while working on it. There is enough wire to allow you to do what you need if you are just careful not to snag it on anything.
    Michael Payne - 回复
    I, too, left the connector attached and just took care that the loose faceplate did not stretch the (not crucial) wire when moving rest of the Wii.
    Matti Haveri -
    This was the trickiest part, I almost broke the wires using tweezers and pliers, so instead use a flat end screwdriver to pry it out, when putting it back in use needlenose pliers to start it then use your fingernail to go the rest of the way.
    grace nicosin - 回复
    After I got the connector out I noticed the little locking flap on the top side of the connector. I think prying this first is the key to easier removal.
    Will B - 回复
    Anyone know of a method to replace the connector if you end up breaking the wires? Bits of wire are stuck in the white plastic connector, so I'm wondering if I can buy a connector online somewhere without replacing the whole face plate. Thanks :)
    Bronze Owl - 回复
    I severed both wires. If you want to avoid removing the connector, you can lengthen the two wires by unserpentining them from the wire holder that's in the cover.
    Griff Derryberry - 回复
    Make sure there is no SD card in your unit before pulling this off, otherwise it'll get stuck and you could snap your sd card in half!
    carlosahiciano - 回复
  7. 如何帮任天堂Wii主机更换光驱, 外壳: 步骤 7 中的图像 1,3 如何帮任天堂Wii主机更换光驱, 外壳: 步骤 7 中的图像 2,3 如何帮任天堂Wii主机更换光驱, 外壳: 步骤 7 中的图像 3,3
    • 打开手柄连接口保护盖,直到它与本体垂直
    • 把盖子直接向上拉,这样就可以拆下盖子
    • 内存卡保护盖也是这么拆
    I wasn't able to reassemble the socket covers when I reversed this step..
    While disassembling, I did as instructed pulling the covers upwards when they where perpendicular to the black cover plate but Nintendos instructions says to open the covers (so that they are perpendicular to the black cover plate) and then gently push the covers towards the console with your fingers on the outside of the cover opposite side of the hinges so that the cover hinges will pop out and then lift it up..
    I'm not sure, but I think ignoring Nintendos instructions caused the hinge sockets to break for me, so replacing the controller/memory card socket covers will not work.
    When reassembling, the cover can be placed perpendicular to the black cover plate and rest on the plastic hinge with a few millimeters between the cover and the console, and then they can be pushed down to click in place. But in my case they keep falling all the way down since there's no resistance and nothing to click into.
    Martin Johansson - 回复
  8. 如何帮任天堂Wii主机更换光驱: 步骤 8 中的图像 1,2 如何帮任天堂Wii主机更换光驱: 步骤 8 中的图像 2,2
    • 拆掉手柄连接口边沿剩下的两颗4.1毫米十字螺丝
    • 在四个角用手拉保护板,即可拆下
    The 3rd hole is in step 3.
    James middleton - 回复
    The bezel is the flat black plate. Removing the three screws that secure it allows you to remove it. If your cube is like mine, this plate likes where it lives and, even with the screws removed, managed to stay in situ without anything holding it.
    Dennis Johnston - 回复
    Beware. The edge of the bezel, opposite these screws, has clips. Lift the bezel from the top edge, where the the screws are, to avoid breaking these clips.
  9. 如何帮任天堂Wii主机更换光驱: 步骤 9 中的图像 1,1
    • 拆掉两颗在手柄接口上5毫米十字螺丝
  10. 如何帮任天堂Wii主机更换光驱: 步骤 10 中的图像 1,1
    • 用一个金属小铲子移开三个螺丝保护盖(图上高光部分)
  11. 如何帮任天堂Wii主机更换光驱: 步骤 11 中的图像 1,1
    • 移开下列螺丝
    • 两颗5毫米十字螺丝(红圈)
    • 一颗8.2毫米三角螺丝(橙圈)
    Instead of the Phillips screw on the left I had a very small one under a cover to the left of that!
    Donna Vought - 回复
  12. 如何帮任天堂Wii主机更换光驱: 步骤 12 中的图像 1,1
    • 用祖传金属小铲子移开在主机下面的橡胶垫
  13. 如何帮任天堂Wii主机更换光驱: 步骤 13 中的图像 1,1
    • 移开两颗8.2毫米三角螺丝,它们在你拆下的橡胶垫下面
    had a little trouble with theses screws. they were just barely too deep for my 54pies bit driver kit to reach. I ended up inserting a small wad of paper into the shaft of my driver so the tri-wing bit stuck out far enough to engage the screw. (I used the tweezers to remove the paper when I was done) :)
    rbelknap - 回复
    I can confirm, this works fantasticly!
    Thank you
    James middleton -
    When putting the screws back in hold the tip still with the screw and carefully drop it in.
    James middleton -
    Thank you rbelknap, this is excellent advice for those using the ifixit branded driver.
    George Squires - 回复
    You could also use the 4mm nut driver in the iFixit kit to turn the tri-wing driver. This will give you a little more reach.
    Edward Tucker - 回复
    How is no one talking about the included 4mm nut driver trick at Edward Tucker mentioned?! That is genius! Thanks mate!
    Zabuza -
    That's the idea that I needed. Agree with Zabuza.
    cwdick -
    Bingo. All of the other comments were unnecessary.
    Tony Shannon -
    Because it doesn't come with the screw driver in the kit. Only has the tri wing and the cross tips.
    Craig Goodsell -
    This paper wad trick totally worked for me too!
    anonymous 779 - 回复
    Standard Tri-Wing bits will NOT fit into the holes. Make sure that you get one of the tool kits from iFixit (I just ordered the Mako Driver/Bit kit with 64 bits ) - the Tri-Wing bits in this kit have a narrow shaft that allows it to reach deep into narrow holes like these on the Wii . (Disclaimer - I have no association with iFixit).
    dave whale - 回复
    I just sawed off a bit of the shank holder from the iFixit tool, in order for the bit to go deep enough into the case.
    The tool still works fine.
    Alan Walker - 回复
    Thanks for the paper wad trick advice! Worked perfectly with my Wii
    Finder352 - 回复
    The 4mm driver was the exact fix for this problem, no mods necessary
    Tony Shannon - 回复
  14. 如何帮任天堂Wii主机更换光驱: 步骤 14 中的图像 1,1
    • 把壳子直接拉开就好啦~~
    This step could use at least another picture from the backside so it's clearer what comes up and what stays down.
    Jose Vazquez - 回复
    I used a spudger around the edges of the outer case to gently ease it upward since I could not lift it out with my fingers. Then it came right out.
    Marko - 回复
    Good tip. Having, in the past, broken pieces that required a little persuasion, I attempted to "lift" the outer case, but it wouldn't budge. Using the spudger to persuade it worked like a charm. Also added this suggestion to Step 18 "Lift the drive shield."
    Dennis Johnston -
    hey marko that really helped me thanks\. als if you need help figuring which side is up, its the one with the nintendo engraving on it
    Aryan Garg - 回复
    A fan filter fell out at this step how do you put it back?
    Edit: I figured it out it was from the side intake vent. Just line up the two notches with the pegs in the case to hold it in place
    Darren Jones - 回复
    This is an awful guide
    Alexander D Schaefer - 回复
  15. 如何帮任天堂Wii主机更换光驱, DVD光驱: 步骤 15 中的图像 1,2 如何帮任天堂Wii主机更换光驱, DVD光驱: 步骤 15 中的图像 2,2
    • 移开位于电池舱门上的十字螺丝
    • 这颗螺丝承载着电池舱门
    • 把电池舱门移开
    • 这是一个更换CR2032纽扣电池的好时机
    The screw on the battery door of my Wii required a Phillips #000 screwdriver, which is not listed in the required tools.
    Ben - 回复
    The screw is a PH0000 (quadruple zero) requiring an exceptionally small Phillips screwdriver to remove. If this is your first time in here in a while, this may also be a great time to change the CR2032 battery.
    Steve Bonds - 回复
    I was able to use the ph0 no problem.
    Darren Jones -
    I used a 00 with no problem.
    julie -
    What does this battery do? I never knew there was a battery inside of the WIi.
    Stephen Thornhill - 回复
    thje battery is used to maintain timwe and date etc
    Electronik -
    Where can we get a new battery from?
    Chriul Rg - 回复
    You can get a CR2032 batterie in your local supermarkt. It is recommended to change it after 5 years, but I have seen devices run for 15+ years.
    Playa -
    my wii survived 15 years already with the same battery
    Bas Molendijk - 回复
  16. 如何帮任天堂Wii主机更换光驱: 步骤 16 中的图像 1,1
    • 拆开在电池舱左边的8.2毫米三角螺丝
    Note - this screw is a machine screw (e.g. not self-tapping). It screws into a hex nut, and that nut is captive in a slot in the case. When reassembling, ensure that this hex nut is still captive, and has not migrated out to other areas within the Wii.
    dyanetti - 回复
    The other drive cage hole is screwed in step 11, continue to reassemble.
  17. 如何帮任天堂Wii主机更换光驱: 步骤 17 中的图像 1,1
    • 拆开两颗光驱和手柄接口屏蔽罩的8.2毫米三角螺丝
    The screw on the right for my wii just refuses to come out
    Robert Menocal - 回复
  18. 如何帮任天堂Wii主机更换光驱: 步骤 18 中的图像 1,1
    • 现在可用直接移开屏蔽罩啦~~~
    Be careful not to cut your fingers on the sharp edges of this metal shield. My daughter actually scraped enough skin to cause blood to drip off her finger. Then we noticed her skin stuck to the metal edge. Yuk.
    J Smith - 回复
    True story I did it to myself lol
    James middleton -
    Does the dvd shield need to be there? I want to remove it but im not sure if i should
    Kadamo - 回复
    If the drive shield needs a little extra persuasion, us a spudger around its perimeter. Also helps prevent cuts when force meets resistance on this metal shield.
    There are spring steel tabs on both sides.
  19. 如何帮任天堂Wii主机更换光驱: 步骤 19 中的图像 1,1
    • 移开这四颗位于底部固定光驱的9毫米十字螺丝
    The two left hand screws were very difficult to relocate during reassembly. I was coaching my 8 year old through this, and this was probably the only step that he couldn't do. We dropped these screws several times, and used magnets to retrieve. Miniature needle-nose pliers gripping the 'washer' surface of the screw were too wide. We managed to purchase the 'button head' of these screws with the needle-nose and drop the screws into their hole, and push with the phillips until secure. I would like to hear how others install these screws, please.
    dyanetti - 回复
    I had the same problem as you and eventually found an easy way round it. I wrote this to be added to the instructions but it was rejected: "Once the DVD drive has been removed, remove the 4 rubber washers from the screws removed earlier and insert them into your new DVD drive. Because two of the screws are difficult to reach, it is best to insert these two screws into the washers and then slide them into place ready for securing to the base plate".
    The rubber washer holds the two screws roughly in position, you can then reach them with your screwdriver through the two holes (about an inch away) and finish tightening them up.
    Gary -
    For the two screws at the front of the chassis, use a three-pronged parts retriever to lift them out after you unscrew them.
    Walter - 回复
    Helpful tip: Use a magnetized screwdriver for the 2 screws nearest the DVD face because they are set in deep sockets
    Blake Minghelli - 回复
    During reassembly, it can be tricky to position the recessed screws. To temporarily magnetize your screwdriver, rub the tip against a magnet for 5-10 seconds. (A refrigerator magnet will do.) You should then be able to put the screw on the tip and gently lower it into position.
    Matt D - 回复
    Thanks - the refrigerator magnet trick worked for me,
    Jim Allen -
    Another method for getting the front screws back in is to insert a small pair of tweezers through the DVD slot to guide the screw in. I just dropped the screw in between the tweezers which held the screw just above the hole. Then I was able to use the phillips screwdriver to guide the screw into the hole and screw it in. Done in just a few seconds.
    Another option would be to stick a dab of hot glue on the screw to your screwdriver and then when the screw has been driven home either the glue stays on the driver and is easily removed or it stays on the screw and you just pull it off with tweezers or needle nose pliers.
    accts4mjs - 回复
    The screwdriver provided in the kit by ifixit is a magnetized screwdriver and works perfectly!
    mulkey - 回复
    If you are disassembling your Wii because, say, a two-year-old has shovelled pennies into it (yes, that was me) you will also need to partially disassemble the drive itself, which is not covered in this guide. Luckily it's really easy. Unscrew the 4-5 larger Philips/cross head screws on the top of the frame (NOT any of the smaller darker ones) around the edges, and the frame on top of the drive will lift right off. Be careful as there is cabling running to it, so don't yank it or pull it too far off. You will now be able to get any coins or other foreign objects out.
    thepitcanary - 回复
    I didn't have a magnetic screwdriver, so I applied a tiny amount of fabric glue to the head of each screw, waited a minute for it to start to harden, inserted my non-mag screwdriver into the screw head, and the screw stuck to the screwdriver long enough to insert it into the hole.
    Lee Crooks - 回复
    Be advised that the posts that these screws go into are very fragile and may even break. Make sure to get the little plastic pieces out if you over tighten them or they are just brittle and broken to begin with. The screws seem to be long enough to work if you do break the posts off completely.
    Michael Payne - 回复
    I needed a size 1 Phillips screwdriver for this step.
    julie - 回复
    Thanks, I will include it in the guide
    Angel -
    Be careful with these screws - they seem to be quite malleable and easy to strip.
    Electronik - 回复
    I ended up using an extra fine tweezers from a watch kit, stuck it through the vent opening "inside" the screw area and acted as guideposts to thread in. Only because I didn't have a magnet for the screw.
    kwjayhawk - 回复
    I guess this is a warning applicable to anything that has to do with plastics, but this step in particular: Be extra careful not to overtighten these screws when reassembling the unit because the plastic sockets will easily break/shatter..
  20. 如何帮任天堂Wii主机更换光驱: 步骤 20 中的图像 1,1
    • 抬起光驱和手柄接口的一部分,这样就可以拿起底部的线缆
    • 超级超级小心的把光驱电源线从塑料屏蔽罩和散热器边上拔开
    When reversing these steps to reassemble the Wii, at this point it is possible to do a quick test before screwing the drive to the case. This will save you a lot of time if something is wrong.
    Don't touch anything you don't have to while the case is off.
    Carefully plug the power cable into the back of the Wii, then use a screwdriver to gently press the white button next to the glowing yellow LED on the front. You should hear the DVD drive power up and whir. Then press the white button again, wait for the yellow light to come back, and unplug the Wii.
    If you didn't hear the drive start up, most likely one of the two ribbons isn't connected to the drive correctly. Doublecheck the previous 3 steps.
    Matt D - 回复
  21. 如何帮任天堂Wii主机更换光驱: 步骤 21 中的图像 1,1
    • 从光驱本体上拔下电源线
    When reversing this step, be careful re-inserting the connector. The pins are very delicate and if you aren't at the proper angle, you can bend them and ruin the drive.
    jisakoff42 - 回复
    The exact thing happened to me just now; I reinserted it at a (very slight) angle, and bent one of the pins at the end of the socket. Luckily, I was able to straighten it back up with a sewing needle. I made sure the spacing was consistent with the rest of the pins, and that I reinserted the connector as straight as I could, so it doesn’t happen again.
    Jose Olarte III -
  22. 如何帮任天堂Wii主机更换光驱: 步骤 22 中的图像 1,2 如何帮任天堂Wii主机更换光驱: 步骤 22 中的图像 2,2
    • 用指甲(强烈推荐翘棒qwq)把光驱信号排线卡扣翻开
    • 确认你开的是卡扣,不是排线座(真要是排线座被你搞下来那你玩的太大了)
    • 把排线拔下来
    • 移开主机的光驱
    When reversing this step, make sure the ribbon is all the way in. For some reason I found positioning it with my replacement drive was much harder than with my old drive. The gentlest tug after lowering the brown clip would show that the ribbon was not actually being held tightly. I thought for a while that the clip itself was broken, but eventually I got it to hold the ribbon correctly.
    Matt D - 回复
    Be careful with this step. I too had difficulty re-inserting the ribbon. I even popped off the brown clip and thought I broke it. Thankfully it snapped back into place.
    Dana Kennard - 回复
    It is difficult to tell, but be aware that the brown piece is the retaining flap, not the light piece , which is the actual socket.
    Dan Neunaber - 回复
    I had to use Kapton tape. I couldn’t get the clip back on.
    Jim Allen - 回复
    This was the trickiest step for me. Take note of how the ribbon is configured before you loosen the clip to help you replace it with confidence in the right way.
    Ping Wu - 回复
    Careful! When reinstalling, I think I bent and broke the ribbon. The Wii doesn't respond upon power up - I think because it doesn't see the drive.
    Steve Bennett - 回复
结论
要重组设备,请反向操作以上步骤
40等其他人完成本指南。
由衷感谢以下译者:
en zh
75%
Vladimir Chen正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
7条评论
My problem was an object that had been lodged in the drive - in fact, I didn't need to replace the drive. I successfully followed thru step 19, and at that point, I was able to extract the foreign object through the gaps in the disc housing. Then I reversed the steps through to the start and everything is working again.
JJones - 回复
I used this to access the drive area where I successfully identified and removed a plastic toy 50p coin my 2 yr old had carefully inserted in it; The Wii works again now
I am v gratefuil for these excellent instructions
And a tip - use a computer/laptop to view; an iphone was a wee (Wii?) bit too small!
david simpson - 回复
You can also download our free iPad app.
David Hodson -
Your instructions were very thorough, and my Wii now works again, thanks!
Robotai - 回复
I’ve replaced the drive & receive the same error.
it doesn’t appear to read the disc.
Could it be the ribbon cable needs checking or
do you need to run a WII update as the device realises a hardware change and it won’t work until
an update has been run.
Brendon J - 回复
I just rebuilt my Wii following these instructions and it now works great. Thanks!
Deborah Wilson - 回复
Couldn't have done it without your guidance!
1977trojan - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 49
过去 30 天: 232
总计 120,132
