跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
华为 P9 Lite 电池更换
你所需要的
  1. 华为 P9 Lite 电池更换, 后盖: 步骤 1 中的图像 1,2 华为 P9 Lite 电池更换, 后盖: 步骤 1 中的图像 2,2
    • 从底角开始,使用三角撬片打开后盖。
    • 逆时针方向操作,一个接一个地小心地撬开塑料卡扣。
    What could you use instead of an opening pick??
    Alfredo - 回复
    Like, could a guitar pick wor? Or anything else?
    Alfredo - 回复
    A guitar pick will also do.
    Tobias Isakeit -
    what can still be used besides guitar pick
    Tarshia Thompson - 回复
    I had a hard time to open the back cover by opening pick. Then I used little, really little knife at first, and I continue to opening back cover using opening pick.
    Andy B - 回复
    Heating up aroud the finger sensor to loosen the square adhesive tape ..
    Hishamchohan - 回复
    If you do not have any picks, You can also adapt an old credit or utility card by cutting it in to thirds. Then with some fine emery or sand paper, rub a sharp point on the one edge of the card. This will help you get access to the clips that hold the rear cover on. The one i did yesterday had quite a lot of adhesive around the edge & around the finger print sensor. Another tip with an old credit card is to cut it in to narrow strips to insert in to where you have separated the cover from the frame to stop it getting stuck to the adhesive again.
    gazza667 - 回复
  2. 华为 P9 Lite 电池更换: 步骤 2 中的图像 1,1
    • 后盖下方有粘合剂,可将其固定在电池上,顶部装有金属板。
    • 小心右侧的柔性电缆。
    • 拧开三角撬片,将后盖拉开,并将其从粘合剂上松开。
    Most of the adhesive is around the fingerprint cell and on the battery itself. You can slowly pull the back cover from its side but make sure not to break it. Push the mediator or a longer piece of plastic under the back cover to slowly destroy the adhesive.
    Nicolas Combaret - 回复
    Slowly, slowly wins the day. Nicolas is right and comes off a charm. The most nerve wracking part of this longish repair.
    John Nordstrom - 回复
  3. 华为 P9 Lite 电池更换: 步骤 3 中的图像 1,1
    • 当后盖没有粘合剂时,你可以完全用手将其弹出。
    Hi! Im so sad! At the begginig of the operation i ve broken the white seal/connector that in one side is connected to the board and the other side is "glued" to the battery. Can someone help me? how can i solve this?? There is no image displayed on the screen. but there is vibration, sound, notifications... can someone help me please???
    Diogo - 回复
    What you broke is handling the NFC, and doesn’t have anything to do with the display. You probably damaged the ribbon right below the battery, since that’s what links the display to the motherboard.
    Polaris -
    Oups ! L’antenne NFC était solidement collée à l’intérieur de la coque et j’ai donc déchiré sa nappe en ouvrant la coque. Heureusement, je n’utilise pas les fonctions NFC et, à part cela, tout a l’air de fonctionner normalement.
    Michel Orban - 回复
  4. 华为 P9 Lite 电池更换, 扬声器: 步骤 4 中的图像 1,3 华为 P9 Lite 电池更换, 扬声器: 步骤 4 中的图像 2,3 华为 P9 Lite 电池更换, 扬声器: 步骤 4 中的图像 3,3
    • 在手机的底部卸下这些螺丝:
    • 3个2.9 mm 菲利普斯十字 #00螺丝
    • 4个3.8 mm 菲利普斯十字 #00螺丝
    • 现在你可以把扬声器给拿下来了。
  5. 华为 P9 Lite 电池更换, 主板盖板: 步骤 5 中的图像 1,1
    • 拆下固定金属屏蔽板的九个菲利普斯#00螺丝。
    • 如果螺钉顶部有任何水指示器,请将其拆下,以确保螺丝刀能够正确就位。
    Qu’est ce qu’un “indicateur d’eau”?
    chevaliernoir - 回复
    Une petite pastille qui change de couleur au contact de l’eau. Les fabricants s’en servent pour nullifier la garantie : si ta pastille indique que de l’eau s’est infiltré, tu devra payer ta réparation.
    Polaris -
    Are all the screws the same size ?
    Hishamchohan - 回复
    yes they are
    Adam M -
  6. 华为 P9 Lite 电池更换: 步骤 6 中的图像 1,2 华为 P9 Lite 电池更换: 步骤 6 中的图像 2,2
    • 不要拆下屏蔽板,它是通过连接器和电缆连接的。
    • 使用撬棒断开指纹传感器与主板的连接。
    • 将NFC天线电缆从金属板上剥离。
    can we just remove NFC antenna and dont want to install int back?
    Mohd Danial Bin Harun - 回复
    Note there are two plastic tabs at the top of the shield plate. Unlock them with a mediator, the plate will come easily after that.
    Buongiorno,
    va sostituita l'intera piastra metallica contenente il sensore impronte e la fotocamera, oppure il sensore é estraibile dalla piastra?
    Grazie
    LUIGI
    GI GI - 回复
    Yes, it is possible to remove just the fingerprint sensor from the motherboard shield. Remove the small metal plate on the inside of the shield covering the sensor and push the fingerprint sensor through from the other side.
    Tobias Isakeit -
    Grazie mille.
    GI GI - 回复
  7. 华为 P9 Lite 电池更换, 电池: 步骤 7 中的图像 1,3 华为 P9 Lite 电池更换, 电池: 步骤 7 中的图像 2,3 华为 P9 Lite 电池更换, 电池: 步骤 7 中的图像 3,3
    • 拆下连接两端主板的排线并将它取下
  8. 华为 P9 Lite 电池更换: 步骤 8 中的图像 1,2 华为 P9 Lite 电池更换: 步骤 8 中的图像 2,2
    • 从电池上剥下NFC天线。
    • 小心不要撕裂或弄皱天线。
    • 如果你只是需要取下电池看到显示屏,那么可以把NFC天线留在电池上。
    • 拔出电池排线
    The NFC Antenna is delicate. If you are just replacing the batter then i had to use a bit of heat to soften the adhesive before gently peeling it away from the battery. The adhesive is quite stubborn.
    gazza667 - 回复
  9. 华为 P9 Lite 电池更换: 步骤 9 中的图像 1,3 华为 P9 Lite 电池更换: 步骤 9 中的图像 2,3 华为 P9 Lite 电池更换: 步骤 9 中的图像 3,3
    • 将spudger滑到图片所示位置的电池下方,慢慢撬开。
    • 小心不要损坏电池中央下面的显示屏排线。
    Bonjour j'ai réalisé toutes les etapes mais mon telephone ne se charge plus.que faire ?
    Amenis - 回复
    Bonjour ! Alors deux options sont possibles :
    1) la batterie était complètement vide et cela prend du temps avant que le téléphone s’allume et affiche que la batterie est en train de charger.
    2) vérifiez que les connexions des nappes à l’intérieur, surtout celle de cette étape. Cette nappe relie en effet le circuit inférieur au supérieur, fait donc le lien entre la batterie et le port de recharge.
    Bonne chance !
    Claire (iFixit EU)
    Claire Miesch -
    Super !
    J’ai réussi. Le plus pénible sont les différents endroits collés.
    Particulièrement sous la batterie… et l’antenne NFC ! Qu’on ne peut pas recoller ! (jai mis du scotch, j’espère que ça ira…)
    A priori, le sèche-cheveux aide un peu pour ramollir la colle sous la batterie.
    J’ai pu aussi enlever de la colle en soulevant l’autre côté (doucement). Prendre son temps est essentiel ^^
    Par contre pas remis de l’adhésif dessous comme indiqué.
    ChtiClem - 回复
    The battery i removed yesterday had way more adhesive on the under side than in the above pic. I ended up having to get the old battery fairly warm before the adhesive would release. A tip if you are doing this is to use an old credit card cut in to narrow strips and insert them in to the gap where the adhesive release. That way the battery shouldn’t re-stick before you remove it.
    gazza667 - 回复
结论
按相反的步骤组装你的设备
86等其他人完成本指南。
由衷感谢以下译者:
en zh
85%
天下有狗狗正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Tobias Isakeit
于03/31/14注册
117,598 声望
创作了188篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,534篇指南
24条评论
There is an extra step where you need to remove the cover of the board at the top of the phone in order to remove the NFC antenna which is not described in this guide. Better watch this https://www.youtube.com/watch?v=ADZiL7JK...
Costas Geraniou - 回复
Thanks Costas for the hint. We added the missing step.
Tobias Isakeit -
Very very thanks!
Artur - 回复
Cercando di rimouorere l'adesivo dell'nfc si è rotto, posso assembrale il telefono senza nfc, ovviamente invalidando questa funzione?
Francesco Staiano - 回复
Si, hai ragione: si può riassemblare il telefono senza l’antenna NFC perdendo questa funzione…
Claire Miesch -
Helpful but now the fingerprint sensor and NFC don’t work, double checked the connector has been replaced correctly any idea on what might have gone wrong?
ben_goold - 回复
Maybe you want to check that the fingerprint sensor connector is properly seated and that the cable is not nicked or ripped. Same goes for the NFC antenna. Check the wiring of the antenna and that the contact pads and springs on the mother board meet.
Tobias Isakeit -
This was very helpful, my phone works perfectly fine.
lisb4429 - 回复
About removing the battery from the casing ... use fishing braided line. that works better :) Battery extracted without destruction.
Slawomir Z. - 回复
Great tutorial. Worked like a charm for me. I definitely recommend buying the iFixit kit. Couldn't have done it without it.
Roban - 回复
Muchísimas gracias por tu detallada explicación.
Pedro Medina Garcia - 回复
Hello.
These black stickers are left on the battery, what they are used for and whether they need to be changed. I have a new battery without its.
Kristof P - 回复
Tutoriel à la fois simple, précis et très explicite. Je l’ai suivi pas à pas et je n’ai eu aucun soucis.
Vraiment merci beaucoup.
Fabrice Niel - 回复
Dopo sostituzione batteria display non funziona. Cosa sarà successo e come ripristinare funzionamento? Grazie infinite a chi mi saprà aiutare.
pasqualealessio - 回复
Prova a controllare che il connettore sia connesso correttamente
Emilio -
I completed the procedure without removing the audio board as described in step 4. I just disconnected the other end of the cable from the mother board and completed the other steps, it worked just fine.
Emilio - 回复
Ciao, dopo aver cambiato la batteria il microfono inferiore non funziona. Avete qualche suggerimento? Qualche aiuto? Grazie
fabio9999 - 回复
The battery was glued very firmly. Therefore, when it was removed, it was bent and became hot.
Johannes - 回复
Perfetto, ma dopo aver sostituito la batteria non mi funziona più il GPS ! Qualcuno sa aiutarmi ?
marcellomaura - 回复
Bonsoir est-ce qu’on est vraiment obliger d'utiliser ruban adhésif double-face tesa ?
Roronoa Zaza - 回复
You can use any brand. Just make sure the tape is not too thick (so nothing you’d use for fixing down a carpet ;)
If the remaining adhesive is still sticky enough you might get away with re-using it. Having a rattling battery in your phone is somewhat annoying so you better fix it somehow.
Tobias Isakeit -
Many thanks, helped me a lot!
Nicholas - 回复
A million thanks !!!
Pat Lec - 回复
You’re welcome :)
Tobias Isakeit -
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 53
过去 30 天: 207
总计 132,086
