跳转到主内容
OBSOLETE - How to Remove a stuck game from an Xbox 360
你所需要的
  1. OBSOLETE - How to Remove a stuck game from an Xbox 360, Remove the faceplate: 步骤 1 中的图像 1,3 OBSOLETE - How to Remove a stuck game from an Xbox 360, Remove the faceplate: 步骤 1 中的图像 2,3 OBSOLETE - How to Remove a stuck game from an Xbox 360, Remove the faceplate: 步骤 1 中的图像 3,3
    • Remove the faceplate from the system. Grab a part of the faceplate, and it should come off.
  2. OBSOLETE - How to Remove a stuck game from an Xbox 360, Find the emergency eject hole: 步骤 2 中的图像 1,1
    • With the faceplate off of the 360, find a small hole on the front of the 360 without the faceplate and stick a paperclip in the hole. This will be found under the X relative to the faceplate on the system.
    • The system in the guide does not have this hole. In this example, opening the console is likely the only way to get your game out if the optical drive does not respond.
  3. OBSOLETE - How to Remove a stuck game from an Xbox 360, Replace the faceplate: 步骤 3 中的图像 1,3 OBSOLETE - How to Remove a stuck game from an Xbox 360, Replace the faceplate: 步骤 3 中的图像 2,3 OBSOLETE - How to Remove a stuck game from an Xbox 360, Replace the faceplate: 步骤 3 中的图像 3,3
    • Reinstall the faceplate on the system. To do this, put even pressure on all parts of the faceplate until it is completely flush with the console.
    • If you are in doubt, it may not hurt to run your hand over the faceplate to make sure and do a visual inspection.
结论
19等其他人完成本指南。
Nick
于11/10/09注册
88,851 声望
创作了49篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,535篇指南
2条评论
will this work for elite 250 gug
duangphetv - 回复
I have my xbox here but in the pictures I think I have a upgraded xbox 360 and it does not have some of the buttons it had on the pictures but I can't find a place to un clip the face of it
Maddy - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 31,406
