Battery
热门论坛问题
提问这里还没有问题。成为第一个提问者吧!
工具
下列是修复此设备所需要的常见工具,但您可能不需要某些工具。
Sold as rechargeable, multi-use LED travel light that can be attached to a rucksack when riding a bike, clipped to a book as a reading light, or used as a small torch.
Specifications
- size when unfolded: 58.42 x 147.32 x 33.02mm
- weight: around 70g
- clip material: metal with rubber anti-slip-grips
- case material: plastic
- colour (case): available in black, blue, red, white
- light: 4 white LEDs
Operation
Rechargeable via mini USB cable. While charging, the centre LED shines red; once it's charged, it switches to green.
The only switch is located at the top of the light and is touch operated. It is used to switch the light on and off (long touch) and to switch between modes (short touch):
- 4 LEDs permanently on
- 2 LEDs permanently on
- 1 LEDs permanently on
- 4 LEDs flashing
The light is attached to the clip via a ball joint. This enables it to be turned sideways while reading to light different parts of the pages. Also, when turned around by 180°, it can be folded onto the clip for using it as a rucksack light or for storage.
