跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
Proximity sensor is STILL not working
I bought this phone off eBay knowing that the camera doesn't work and it came without a screen... So I basically replaced everything in it... Including the camera to see if it would work (it didn't ) , the one issue that has always annoyed me greatly is the proximity sensor, it's so annoying the way it doesn't black out when I'm making a call and I always hit the mute button with my face.
I have even bought the little sticker that says it fixes the problem but it still does nothing . I'm also on the latest firmware 5.1.1
I also tried using scotch tape to cover up the sensor then coloured it with black marker .
Nothing has worked . I've also tried completely replacing the proximity cable twice and still nothing , any ideas ? I'm on the verge of selling this if I can't fix it, thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
been having the same problem, tried different pieces. works with an original like a charm. what is wrong with these sensors? original screen, original small filter and still no fix...
完成的
添加一条评论
1个答案
已选择的解决方案
bump
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 612
