跳转到主内容
加入维修社区 - 创建账户
This Power Mac G4 has Mirrored Drive Doors.
System Back Up my G4
Hi I'm a bit of a duffer so please excuse me if I get things a bit wrong.
I have a Apple Power Mac G4 DMM 867 .
I have had it from new and am now on OS Tiger.
We have recently had power cuts due to thunder and lightening and I got worried if I couldn't bot up!
My question is: How do I do a system back up in case I loose everything?
Regards Jim
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
Thank you for your help.
Jim
完成的
添加一条评论
1个答案
已选择的解决方案
Purchase a UPS (uninterrupted power supply aka:backup battery) they are good for a number of reasons. 1 they protect against brownouts (voltage drops-as damaging as surges)... but surge protectors do not address this problem. 2 They also isolate phone/data lines from lightening strikes. You don't need a large expensive unit one around $100.0 US should do.
Easiest way to backup is to purchase an external drive larger than your laptop drive in size. (I think for a G4 machine you're going to need a Firewire (aka:IEEE 1394) connection to that drive) Format it via Drive Setup (You want the Mac OS Extended format)
If you leave the drive connected you can use an automagic backup application scheduled to backup as often as you like, backups that aren't kept up are just a bit more than useless (there were some good free ones for OS 9/early OS x - I like LaCies Silverkeeper (works on any hardware).
If this answer was helpful please remember to mark it accepted.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 687
