跳转到主内容
加入维修社区 - 创建账户
Model A1046 or A1095 / 1280x854 screen resolution
No chime upon startup
I just reassembled my laptop, and I do not hear the apple "chime" upon start up. The computer does seem to be functioning normally, but I always heard the chime in previous macs I have owned.
Am I being paranoid, or should I just ignore this? Thanks for any input.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Does the computer work fine? or will it not turn on? Do you hear sounds when you turn the volume up or down, can you not hear any sound? If you can't hear anything, chances are that you might have unplugged the internal speakers somewhere during the keyboard replacement.
完成的
添加一条评论
3个答案
已选择的解决方案
See if it boots up, are you using the original keyboard, or the replacement one you mentioned in annother question? Try to put in the original keyboard if you haven't already. Check your RAM, try to reseat it, since you could have knocked it out of place. Also try reseting the PMU, and the PRAM.
这个答案有帮助吗?
得分 2
添加一条评论
Check that your volume is not muted.
这个答案有帮助吗?
得分 1
2条评论:
or speaker wire disconnected/broken.
完成的
Yes or course, that too, but sometimes the most obvious is the least obvious
完成的
添加一条评论
Thanks for all the help. The computer seems to be running fine. I played a few songs through itunes and they came through the computer speakers fine, but still no chime when I boot the computer. I am at a lost as to why this is happening. I am hoping someone with a little more experience can explain this to me. Again, thank you for all your help.
Charl
这个答案有帮助吗?
得分 0
1条评论:
I had a similar problem and cured it by reseating the ram and as Chris said reseting the PMU. Ralph
完成的
添加一条评论
添加你的答案
Charl 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 16
总计 2,216
