跳转到主内容
加入维修社区 - 创建账户
发布于2011年7月21日。Core i5或Core i7处理器。雷电(Thunderbolt)接口。本机也用于Mac mini Server配置。
Installing of two SSDs
I have mac mini mid 2011 with code i5@2.3GHz
Two days ago my Dual HDD kit arrives, and i have tried to intall two SSD disks in my mac... but without success:
I have opened my mac, and installed both two SSD disks (OCZ Agillity 3, 120GB). Everytning was good, till I turned on my computer: both SSDs are recognised, but one of them (this on the second SATA port) I'm not able to partiton or format.
Ihave opened my mini again, connected the disk to my Macbook Pro, and installed OS X 10.8 without any problems. I have put it back into the mini - same problem again: SSD is recognised, partition not...
At last, I have installed my original HDD (500GH Hitachi) on the second drive bay, and now it works without any problem...
Is it possible to have two SSD disks installed in my mac mini?
My plan is to install two SSDs and to configure RAID-0.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The note I see here says: A second hard drive or SSD also can be installed, although it is not formally supported. (that usually means cheap or generic parts won't meet requirements, but certain more quality controlled {expensive} parts do) Contact the vendor of the dual HD kit for their help/support/replacement of part.
If this answer was helpful please remember to return an mark it Accepted.
这个答案有帮助吗?
得分 1
2条评论:
Dual HDD kit is ordered from iFixIt, and it works:
There is no problem if I connect my original HDD - 500GB Hitachi.
So, the facts are: both ports are identified as:
Intel 6 Series Chipset:
Vendor: Intel
Product: 6 Series Chipset
Link Speed: 6 Gigabit
Negotiated Link Speed: 6 Gigabit
Description: AHCI Version 1.30 Supported
But when I connect an SSD to the "second" port - it not works.
Any HDD works, by the way.
I have read from many other sources, that the problem is in OCZ, and I must order Samsung or OWC SSD disk...
Here is my SSD:
[image|180290]
And here is my HDD:
[image|180291]
完成的
That's what I said - some parts will work, others wont. =8^o
完成的
添加一条评论
添加你的答案
Dimitar Terziev 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,050
