跳转到主内容
加入维修社区 - 创建账户
MacBook won't turn on with isight / airport connected to logic board
Hello. I've been given a Macbook Pro where, it seems, the Airport cable was connected backwards. It was turned on, smelled funny, and was turned off. Now, when the cable for the isight / airport is attached to the logic board the system won't start at all. Remove the cable, it runs fine, but without isight or airport.
Any ideas? Is it the logic board, isight, airport, the cable? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Since it starts without the iSight, Airport cables you can rule out the logic board. The camera cable AFAIK is not near the bluetooth/airport connector. Try one connector - to the correct spot - insulate the other connector. I think you may have blown the bluetooth/airport card. When booted what does System Profiler:Bluetooth, then Network lastly Wi-Fi reveal about the state of your cards.
If this answer was helpful please remember to return an mark it Accepted.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
RN74 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 660
