跳转到主内容
加入维修社区 - 创建账户
Apple hardware test Failure code...
After running a aht it gives an error : 4SNS/1/40000001: VP0R-0.000
what is the exact problem in this logic board. System is very slow . i already dismantle 3-4 times some time after assembly it works for little time means working until restart. after restart it again giving same problem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
If i Plug the Charger in then the laptop works fine no problem. while on charger also AHT gives same error . What to do??
完成的
I see two possibilities; use it as is, or, replace the logic board.
完成的
What did you do in the end ? I have exact same problem. Dont no weather to get fixed or not ?
完成的
添加一条评论
1个答案
已选择的解决方案
Run the extended version of the Apple Hardware Test. Sometimes you will get an error if you run the quick version, and it may be something of a false positive. Some have found doing an SMC reset 3 or 4X can eliminate the error (note: a work around not a fix). If it is indeed a logic board error it points to a sensor(s) failing, VPOR might be VGC(VPU) related. You'll probably need a new logic board, AFAIK sensors as well as the VGC are soldered to the logic board which pretty much makes them non-DIY repairs, as soldering on logic boards are not for amateurs.
If this answer was helpful please remember to return an mark it Accepted.
这个答案有帮助吗?
得分 4
3条评论:
i already done SMC or PRAM, can you locate the specific sensor which creating this problem ? thanx in advance
完成的
Nope - looked but "best guess" was all I could offer.
完成的
it was the error of sensor on the logic board . i replaced the logic board
完成的
添加一条评论
添加你的答案
SIMRAN 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 6,770
