跳转到主内容
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
Replace Superdrive with SSD
Hello!
Advise me please, can I replace Superdrive with SSD on my Imac 27' 2009 with this kit - iMac Intel 27" (Mid 2011) Dual Hard Drive Kit
Thank you for help.
Install an additional 2.5" SATA hard drive in your Mid 2011 27" iMac.图片
产品
$27.99
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
No: Compatibility
  • All Mid 2011 27" iMacs
If this answer was helpful please remember to return an mark it Accepted.
这个答案有帮助吗?
得分 1
4条评论:
Thank you! But how can I open my iMac and change Superdrive?
完成的
Follow the guide for your machine. Be sure you purchase the required tools: # Heavy-duty Suction Cups # T9 Torx ScrewdriverBuy it # T10 Torx Screwdriver every job is easier when you use the proper tools.
完成的
Thank you! What SATA Power cable I need for SSD?
完成的
I would expect the correct kit to have what you need, other than tools.
完成的
添加一条评论
添加你的答案
wizard 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 9,994
