iSight light is always on
The green "camera is on" iSight light to the right of the iSight is perpetually on! I know that the camera is not actually on (the cable is not even connected), but it is still unnerving. Any ideas?
这是一个好问题吗?
You should try disconnecting the cable to the light (if possible) and reconnecting it to see if that helps
评论:
Well, this didn't fix the problem, but it gave me the motivation to open the machine and disconnect the cables. The light is definitively off now! Thanks!
由 Ben Eisenman 完成的
I can see you!
由 11team 完成的
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 2,503
the fact that the camera is disconnected does not stop the rest of the circuitry to switch off / on. So is the camera actually on when you connect the cable?
由 Spikey2 完成的
