Phone makes continual clicking sound
My phone is making a clicking sound about every 30 seconds (extremely annoying!). Took the back off and it sounds like the noise is coming from the upper left-hand corner, just below the camera (or around that area).
I have looked at forums online to try and find a fix but everyone else says that when they apply pressure to the phone it makes the sound. My phone CONTINUES clicking at a regular interval.
Also, my battery has been draining at almost 10 times the speed! I have to charge it 2-3 times a day.
What I need to know is what part I need to replace or how to maintenance it?
or if anyone knows how to troubleshoot this issue
3条评论
I'm having the exact same problem! also my phone doesn't hold a charge at all, holds up to 3% then dies again, can this be something to do with the noise coming from the lens??
由 sarah 完成的
Turn off Google notifications. It will stop ticking.
由 William Hart 完成的
Mine started doing this also but the sound was irregular and seemed to happen when I tilted the phone side to side but only certain ways. I had just downloaded two apps and one of them caused this. After a few minutes using process of elimination problem was solved.
由 nighthawk 完成的
