跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Is the SSD replaceable in this model?
So I've seen another member ask this type of question, but it didn't quite answer my question. So if I have a 2.3ghz model, and it came with a 256gb SSD, will the parts from a 2.6ghz model that comes with a 512gb SSD work? LIke if I take out the 256gb SSD and replace it with a 512gb SSD from the 2.6ghz model. Just wondering if it works, if it doesn't, I think I'll have to wait for OWC..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Yes they should - Apple will build it that way for you (the 2.6ghz is a custom build up of the 2.3ghz model). I don't think that it would be cost effective-but if you could luck into a damaged 2.6GHz model with a working 512GB Samsung flash memory module it will work. That's still the great thing about Apple - if it "fits" it generally works.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for the answer!
完成的
添加一条评论
OWC
480GB Aura Pro 6G Solid State Drive
http://eshop.macsales.com/item/Other%20W...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
04Stan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 1,183
