跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
Remove or leave Film on LCD + Digitizer?
Hello everyone,
I'm rather new with replacing LCD's, but I managed to do one yesterday. For some reason I noticed a back film on the LCD + Digitizer looking like this:
Click photo!
Do I have to remove this one or not?
Greetings,
Mittchel
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Yes you must remove it or the screen won't work. I experienced this with a new iPhone 6 screen where the apple logo just kept flashing and would not respond to a reset via iTunes. Such a simple oversight which cost me hours of unnecessary work!!
完成的
添加一条评论
2个答案
已选择的解决方案
Yes, remove this protective plastic sheet right before you install the Front Screen. Often there is a tab to help remove it like in your photo. Some Screens don't have the tab on the plastic, but you still remove the plastic sheet.
这个答案有帮助吗?
得分 4
8条评论:
Thanks. I wasn't sure, because in most videos they don't remove it. By the way.. does NOT removing this film this problem: Help needed! Strange colors on screen
Or is that something else?
完成的
So i tried to do the same but when i pulled it instead of the film coming off it pulled the whole thing off.. Is there any way i can fix this? Email me at corygandy@hotmail.com if you can...
完成的
Please answer the query of Mittchel. Does not removing the back film cause any problems?
完成的
Before assembling, I hooked up my new screen to test it. The film was still on the back and it worked fine. Digitizer fine too. But remember the phone can get pretty hot in the sun so it is probably best to remove the film so it doesnt melt inside the phone. I believe the film is even put there so that debris doesnt stick to the metal foil berore it is installed. That way it can conduct heat away better. I'm just guessing about that though.
完成的
Oh BTW this was an iphone 4.
完成的
显示更多的3条评论
添加一条评论
i have this same issue, i didn’t remove the film on my iPhone X screen replacement, now suffer random black screen while using the device most commonly noticed it will happen when changing orientation on my iPhone (Literally not orientation lock)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mittchel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 73
总计 24,998
