跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
iPod Touch lock button is jammed, How to fix?
It's stuck down and i can't get it back up, my home button stopped working a while back so without the lock button i can't power on my device.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
You will probably need the buttons replaced. Sadly the 4th gen is a PITA to open and the lock button flex cable is soldered to the motherboard making replacement hard. If your volume buttons still work and you don't want to fix the other buttons, you could try to jailbreak the ipod, then you can install an app that lets you use reconfigure the volume buttons to act as the home and/or lock buttons.
hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
whats the app called?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jose Anaya 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 11,558
