跳转到主内容
Apple制造的一体机。iMac从2006年1月起配备Intel处理器
7466 个问题 查看全部
问题已关闭
Broken LCD cable on 2011 iMac
I just bought an ssd drive for my iMac, installed it, then put the iMac back together. I turned the iMac on and saw no picture on screen at all. I opened up the iMac again and saw the LCD cable was unplugged. I tried to connect it again but I must have damaged it whilst putting it back as it now looks a bit bent in the middle. I have tried for hours to get it to work again, but to no avail. My question is, do all iMac LCD cables work with the 2011 version? I have done a search for model on the lead, which is 593-1050 and cannot find much info about it, so I am just hoping that other model cables can be used. Otherwise, I am at a loss :p
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hey there Matthew. Unfortunately, the LCD cables are not consistent across iMac models. Also, the LCD cable is part of the LCD itself, so you would not be able to replace the cable independently.
When you first turned the iMac on, was the display completely blank? Or was it just white? Sometimes it takes a while for the iMac to boot up after disassembly and during that time, the screen will just remain white.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 1,625
