跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1158 个问题 查看全部
问题已关闭
Black Display After Repair
Hello.
I Changed The Display-Assembly (Display and Glass), now the iPhone 3G Screen is Black.
1) Reboot (Hold and Home) doesn't work
2) Restore (Itunes 3.1.2) doesn't work
3) Re-Disassembly with replacing Battery doesn't work.
I-Phone is Running, Vibration OK, Sounds ok, ..
If i Take a Screenshot of iPhone it's black.
What can a do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This is what i would suggest.
Take it apart, down to removing the logic board. Sometimes when you recontact the logic board and the battery it seems to work.
I wouldnt advise it but you could just remove the four screws on the right side of the logic board and then tilt it off the battery connector leads in order to recontact the logic board. I wouldn't advise it because you could bend or snap your board, but this is the way i did it.
Sometimes its not the front assembly ribbons but the other ribbons or the contact between the board and battery.
If that does not work let me know and i will suggest another way.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,209
