跳转到主内容
加入维修社区 - 创建账户
24英寸显示器,内置iSight 摄像头,麦克风和扬声器。 1920*1200分辨率。 发布于2008年10月 型号为A1267
No Image on Display
Hello Everybody,
I'm new here and I try to do my best with my english.
My ACD 24" Don't work. It will be not detected from my MPB 15, but ISight speaker USB all sims to work. Just I get no Picture. I measure the Voltage and I see follow:
TP 81 and TP 12 have no Voltage when the Display internal cable ist plugged.
Can be a bade Fuse the reason? Do you know where can I find the Fuse?
Thanks a lot in Advance!
Best Regards,
Yako
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The problem could be on the computer side, especially if you are using adaptors to get the signal to the monitor. Try a different monitor using the same cabling. If a different monitor works then review these Answers to a similar problem.
If this answer was helpful please remember to mark it accepted.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Yako 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 3,812
