跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
iPhone 3GS won't connect to cell network after battery replacement
I just replaced the battery in my 3GS following ifixit directions. Everything else works fine but the phone will not link up with my cell provider and only shows "No Service". It connects to my wifi network but no phone service.
I opened it back up and double-checked all connections, reassembled it, re-inserted the SIM card. Still no service. Tried a hard reset. Still no service.
Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
6个答案
最有帮助的答案
Try setting the date and time manually, SettingGeneral/Date&Time/SetDate&time/TimeZone. I experienced the same problem you did after I replaced my battery. I noticed the time and date was wrong so I manually set it, once I did that the problem was corrected. Hope this helps.
这个答案有帮助吗?
得分 4
2条评论:
Thanks, you are amazing it worked for me!
完成的
Should i say.. thank you so much im from the philippines and i just changed my iphone 3gs battery... And changing the date really works!
完成的
添加一条评论
Is the iPhone reading your SIM Card? Settings App>General>About>ICCID # is it there?
Toggle ON and OFF Airplane Mode, several times, leave it on. Settings App>General>Reset>Reset Network Settings.
Before opening and during repair of iPhone 3GS make sure it is OFF.
Check your work again, #7 connector can seem to be snapped into place but it is not. The two gold prongs near #7 must be in contact with the back case metal bezel.
If everything is good, hopefully you did not dislodge or damage the blue inductor on the logic board near the gold prong.
这个答案有帮助吗?
得分 2
2条评论:
Thanks for the suggestions Brad. It is reading the SIM card. Toggled AP mode several times - no effect. Tried resetting network settings. Same.
I disconnected #7 and reconnected it again to be sure that it was connected properly. The two gold prongs are there and appear to be in contact with the body of the phone. Is there any other way (other than visual) to confirm that they are touching?
I don't think that I did anything to the blue inductor that you mentioned. Everything went fine on the battery replacement so I didn't have to force anything so I wouldn't think that it is damaged.
Any other ideas I can try?
完成的
Thanks Brad for the hint with the ICCID. I am have a similiar problem right now. But I believe it's OS6 related. I had about 5 customers already since the release of OS6 with the "searching..." for signal problem. and if you remove the SIM it still says "searching..." resetting the network settings didnt work. Only a restore from itunes works.. hope they'll release iOS 6.1 real soon...
完成的
添加一条评论
I had exactly this problem and doing the time and date manually worked a treat.
这个答案有帮助吗?
得分 0
添加一条评论
wonderful... same problem!!! connect to pc and automatically set date and time via itunes and so set airplane mode on and off worked fine!!! great site and great post!!!
这个答案有帮助吗?
得分 0
添加一条评论
After having wasting sooo much time just setting date & time worked, Thanx buddy
这个答案有帮助吗?
得分 0
添加一条评论
Wow thi solution worked on my galaxy :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Scott 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 4,420
