跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2201 个问题 查看全部
问题已关闭
Are there different hardware versions of the iPhone 4S?
I have been receiving conflicting information, both from forum posts and from AppleCare. Apple reps have told me that there are in fact two different versions of the iPhone 4S, while forum posters are swearing that all 4S are the same leaving the factory.
In your tear-downs, have you noticed hardware differences between the Verizon, Sprint, AT&T, or retail unlocked versions?
Thank you for your time
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
6个答案
已选择的解决方案
There is a single iPhone 4S.
This is confusing. There is:
1) iPhone 4 GSM - this iPhone does not have Siri.
2) iPhone 4 CDMA (Verizon and Sprint) - this iPhone does not have Siri.
3) iPhone 4S (one iPhone all identical, compatible with GSM and CDMA) - this iPhone has Siri.
这个答案有帮助吗?
得分 2
添加一条评论
Yes! there are two distinct versions, as the cell networks use different technologies which require differences. This is no different than any other cellphone maker that offer CDMA & GSM phones.
The guts are different and the cases them selves are slightly different (antenna & SIM slot). The IOS GUI, Apps and the controls are the all same (just minor control settings differences).
Make sure you get the correct one for the cell network you'll be accessing.
这个答案有帮助吗?
得分 1
添加一条评论
A CDMA iPhone (Verizon) does not have a SIM.
It does not have a SIM slot on the side of the phone either.
So there is 1 difference that makes for 2 different hardware
iPhone chassis/cases.
这个答案有帮助吗?
得分 0
1条评论:
Some of the guts are different like cables and speakers and antennas.
This happens because with no SIM slot there is more room inside
The phone and they arrange things slightly differently.
Many parts are the same - I'm just very careful and confirm
That each part I buy is made for my exact model.
Know our model number when ordering.
完成的
添加一条评论
The answers on this post are all wrong.
The original question was about the 4S and the answers given were for the 4.
For the iphone 4 there is no sim for sprint. For the 4S there is. I just tore one down and replaced the screen yesterday. It had a sim.
The hardware SEEMS to be exactly the same. The part of the phone that utilizes CDMA or GSM is a chipset on the motherboard itself. Not in the internal midframe assembly.
Update
Ok I get how he put it now. Brad is correct.
这个答案有帮助吗?
得分 0
1条评论:
Sorry Kris but Brad is totally correct, you must have read it wrong.
完成的
添加一条评论
Actually there are hardware differences between US/global and EU versions. The top antenna is tuned differently, possibly to comply with local RF standards. Otherwise they are pretty much the same. The BOM option list has 9 entries: GU US/ GUC US/ GU EU. Each with 3 sub models of different storage capacity. These are very subtle differences, I didn't notice until recently.
As for the GU and GUC differences, they share the same hardware but with different burnt-in programming. The GUC ones are provisioned with MEIDs to work on CDMA networks while GU ones are just regular GSM/UMTS phones. These are supposedly software controlled but done in the factory with low level direct programming. Not possible to change outside the factory or it is even meant to be permanent
这个答案有帮助吗?
得分 0
添加一条评论
I know this is an old post but its one of the top google results so I thought I'd chime in. I have replaced dozens of iPhone 4S screens, batteries, back covers, buttons and charging/data ports and was thrown for a loop when I found a new hard frame type today. The standard iPhone 4S replacement screen did required modification to make it fit (by that I mean cutting off screen anchors). Just an FYI in case your newly purchased screen doesn't fit.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 3
总计 3,193
