跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2396 个问题 查看全部
What do about rice stuck in SIM card slot?
I noticed "Samantha" had a similar problem, but mine is slightly different. For me, the two pieces of rice aren't in the way of my sim tray at all because they actually found their way elsewhere inside of my phone. I didn't jam or cram them somewhere, they got stuck just by moving my phone.
Should I leave them in there if my sim tray fits? Or will this cause problems?
I also took the back cover off hoping to find them, but had no luck. Is it possible for them to have gotten under the logic board?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
It is not recommended that they stay in the phone. Even if the phone would work now, the rice could cause something to fault in the future. The best thing to do would be to take the phone to someone who knows what they are doing and allow them to take the phone completely apart in order to remove them completely and then you will have peace of mind that it is all working properly. That would be my recommendation.
这个答案有帮助吗?
得分 1
2条评论:
Thank you. As much as I don't want to spend the extra money doing so, I also feel this is the best thing for me to do. It's just unfortunate because I was so excited my phone turned back on (since it only had "water" damage from exercising) only to find those two measly pieces of rice in the SIM slot :(
Anyways, thanks again, Michael!
完成的
You're Welcome
完成的
添加一条评论
I would just not drop my phone in water so I wouldn’t have to put it in rice in the first place
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Camden 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 3,293
