跳转到主内容
The late 2005 Power Mac G5 was introduced in October, and discontinued in August the next year. There were three configuration options, one dual core processor at 2.0 GHz, one dual core at 2.3 GHz with model number A1177, and one dual core dual processor (quad core) at 2.5 GHz.
26 个问题 查看全部
问题已关闭
cd rom opens when the system is starting
I have problems with the cdrom, always starting the same when it opens the cdrom tray. replace the cd rom and continues to open whenever the beginners
Update
hello problem fixed
I used the mouse that made ​​the cd rom open
the mouse is fine however does open the cd rom
and then removed without opening starts now
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
I suspect the eject button on your keyboard is being pressed or is stuck.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
1条评论:
It might be an uncompleted backup program that wants to write to a disk and is "helping" you remember by opening the optical drive door.
完成的
添加一条评论
Power off the computer.
Disconnect the rodent.
Startup the computer.
Problem gone when rodent disconnected?
Holding down the mouse button at boot time will eject any CD
left in the drive....so a broken/iffy mouse button can cause this.
这个答案有帮助吗?
得分 1
添加一条评论
it can also be from some settings in the startup menu when you boot your computer. When they ask to press F12 or something at the boot to open some settings. I am not a computer wizard, so i do not really know if there is such a setting, but it would be my guess
这个答案有帮助吗?
得分 0
1条评论:
Not on a Mac, they have a dedicated key, no f-keys.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 1,244
