跳转到主内容
加入维修社区 - 创建账户
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
Hard drive connection question...
I recently disassembled my 21.5' iMac and upgraded my 500GB WD hard drive to a 1 TB WD Caviar Black. I made the mistake of not documenting the way the temperature sensing cable was connected and oriented. On my 1st attempt the fan would always run. On my 2nd attempt the fan would not come on. Please help me figure out how this cable is connected. There are 8 pins and only a 6 slotted connector.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
With the underside (circuit board side) of the drive facing you, leave the 2 leftmost pins exposed.
Good job on not switching hard drive companies! You would've needed a new temperature sensor cable if you had switched brands.
Good luck!
这个答案有帮助吗?
得分 2
3条评论:
Thank you Ben. Also, what is the orientation of the connector supposed to be? I figure it might make a difference. Thanks again.
完成的
Is staying with a certain company a good practice for computers in general? Or is it just the iMac?
完成的
The issue is within the HD's them selves. Each supplier uses different pin assignments in the header for the diagnostic thermal sensor which Apple is leveraging. Which is why you needed to stick with the same drive manufacture. Sadly, most of the drive makers don't offer access to this thermal sensor anymore in the newest drives so you need to use this external sensor: WC In-line Digital Thermal Sensor for iMac 2009-2010 Hard Drive Upgrade.
完成的
添加一条评论
添加你的答案
Victor 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 6,690
