跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
问题已关闭
White Rubber Part with Wifi Flex Cable Required?
So I took a part an iPod Touch 4th gen and miss-placed the white rubber part (located in the top left corner) where the Wifi Flex cable is located.
Is this part required still for a functional iPod touch? I do still have the Wifi Flex cable. Just wanted to make sure with the community before giving it back to my friend. Thank you.
http://guide-images.ifixit.net/igi/xHWqj...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I took one of these apart yesterday and found no white rubber as such but did slice through the bit of foam underneath it. It shouldn't case any problems at all, the rubber would be there to support it nicely to the iPod to make sure it is in position. If you want to, try cutting an elastic band into shape and putting it in, maybe even some clay - but, it is up to you whether or not you have stuck the front panel on again.
Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 270
