跳转到主内容
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
MBP is Dead after plug in in of a USB harddrive
Hello,
As I pluged in a USB-Harddrive into the Macbook, it powered totaly off imediately and is dead now.
- Battery LED´s does not light when I press the knob
- The magsafe LED is very dark green and a bit flashing (but not as bright as normaly)
The SMD reset does nothing
Is there a fuse on the board?
is there a chance that it is the RAM?
Is it possible that the MagSafe LED gives error codes?
how much would cost a logic board?
Thanks for your help?
regards
Bodo
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Please, tell us exactly which model of MacBook Pro is it.
Update
Yes, thank you.
I put a link to download ASD (apple service diagnostic)
ASD
这个答案有帮助吗?
得分 1
1条评论:
Thank You very much mistaro & machead3!!!
all tests are Passed,
...It feels better now
I have never heared about crashes that cause this trouble, but my collegues told me they had the same on windows pc when USB devices sometimes pluged in, the solution is allways the same they sayed: no battery & no power while pushing the powerknob to ensure all components are free of voltage, capacitores for example.
In 99% of all cases they had the computer starts normal and it was only a crash 1% leaves in mainboard failure due to a peak overvoltage.
so mr. machead3 you were right, but I had to remove the battery connector too, the Apple SMC reset with buttons did not work.
THANKS ALL, great knowledge here!
respect and cheers from cologne
Bodo
完成的
添加一条评论
最有帮助的答案
If this is still under warranty I'd take it to a Genius bar. There are so many things it could be... If it's out of warranty and you're willing to DIY you could follow the guide to open it. Remove the battery overnight (8hrs) and see if it boots powered only by the magsafe (don't screw it back together - just reassemble on a flat safe surface before applying power- you'll want to put the battery back eventually). If it boots gracefully shut down, remove the magsafe and reconnect the battery... see if that boots.
If this Answer is helpful please remember to return and mark it Accepted.
这个答案有帮助吗?
得分 1
添加一条评论
sorry, is this enough?:
Mac Book Pro 17´´ 8.3 early 2011
- 2.2 GHz Intel Core I7
- Graphic: Intel HD Graphics 3000 384MB
这个答案有帮助吗?
得分 1
1条评论:
Hey, i have EXACTLY the same MacBook Pro and exactly the same problem, did you fixed it ? Please help !
完成的
添加一条评论
Hi thanks for your answer,
Apple warranty is over (April 2011)
I disconected the battery pack connector, then the macbook booted normaly with the magsafe powersuply.
How can I measure the batterypack?
Do you think it is the akku or the mainboard line in between?
regards
Bodo
这个答案有帮助吗?
得分 0
1条评论:
Update: I have reconected the batterie and now it boots normaly!???
Is it possible that a crash is so heavy in Hardware failure????
How can I check the Hardware complete?
I don´t trust it anymore;)
Has anyone heared about such a hardware crash?
完成的
添加一条评论
添加你的答案
felusch 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 7,460
