跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
iPhone charging only while the sim is not inserted
my iphone dropped, worked fine for tow days,
now it keep discharging while connected to charger and turned on, but charging very slowly while turned off,
then i tried to remove the sim an now it works very good with the sim removed charge is lasting for a normal time,
i disconnect it, insert the sim and the charge is drained very fast weak signal and heated. please advice,,, thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Solution is in the last paragraph, cool showing off of my knowledge below!
The iPhone has a small arm underneath the sim card tray which tells the iPhone if it has a SIM card inserted or not, when a SIM card is present, it separates the two metal contacts and so, because there isn't a current flowing the iPhone knows that there is one, and to start powering up and reading the SIM card.
There might, by the sounds of it, be a loose part which is short-circuiting the iPhone, usually from the high voltage line to naught voltage line, that would mean your short-circuiting your house! If you live in Britian you will (by law) have a GFCI (Ground-Fault Circuit Interrupter) If voltage is coming from the live to ground (or zero) then it shuts off the power supply, to stop you from getting electrocuted! In the UK they are annoyingly very sensitive.
As your iPhone is still getting charged a little that means it is passively charging the Lithium battery, which isn't good for the battery life! The iPhone has a miniaturised and adapted GFCI inside of it which will be limiting the amount of voltage the iPhone takes in. In other products it usually warns you and tells you, the iPhone doesn't. Apparently it would confuse people to say 'YOU MAY GET ELECTROCUTED or YOUR iPHONE WILL SOON EXPLODE!'
Don't worry it's not as serious as that, but, as you may have already guessed, you'll need to replace the module were the sim card tray goes. That would be your best bet.
Hope this helps!
这个答案有帮助吗?
得分 0
1条评论:
thanks a lot, this is very informative, appreciate your time.
完成的
添加一条评论
添加你的答案
wessam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 22
总计 8,757
