跳转到主内容
關於自行維修iPhone所需的任何一切,從最新的iPhone15產品線,一路追溯到2007年所發布的初代iPhone。iFixit有著每一台iPhone維修指南、拆解資訊,並且完全免費,還有全宇宙最好的更換配件、工具、技巧!
36472 个问题 查看全部
问题已关闭
My iPhone 3 wont turn on after running out of battery
my iphone 3 ran out of battery last night i charged it on a dock all night and it wontt urn on i plugged it into a usb port about halfa hour ago still nothing there was no traumatic experience invlved it just ran outof battery im a community nurseso really need it to be working please help !!xx
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sounds like a deep discharge, as the battery gets old it loses charge must faster then when it was new, being off for a long time will cause a 'deep discharge' and the time span needed for that becomes shorter with use. Presumably you have had the iPhone out of battery for some time more then usual. You can often fix this by doing an 'over-charge' buy just leaving it on mains charge for what I'd say two days. It should then turn on like usual and just remember not to let it go down too far, failing that, get someone (or yourself) to replace the battery.
Hope this help! xXx
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 1,225
